Forge Farmer 0 #1 Posted May 30, 2017 Hello new member here I have a 753 serial no 62-22031 I need transmission pn3525. The small gear on the end of the cluster gear is ground down so I have no first gear. Was caused by previous owner shifting with a screw driver causing it to atempt getting in two gears at once. Share this post Link to post Share on other sites
stevasaurus 23,620 #2 Posted May 30, 2017 For those reading this...he needs the cluster gear for a #5025 transmission. I would send a PM to @A-Z Tractor here on Red Square. You can also try to get a hold of @racinfool40 (Mike) on facebook / wheel horse junkies. One of these guys will have your part. 2 Share this post Link to post Share on other sites
Forge Farmer 0 #3 Posted May 30, 2017 Thanks for the info Steve. Share this post Link to post Share on other sites
oldredrider 2,553 #4 Posted May 30, 2017 Another option: "new" transmission. I will be bringing a 5025 to the big show. Excellent condition, includes brake band and rod and new boot. Just sayin'... 1 Share this post Link to post Share on other sites
Forge Farmer 0 #5 Posted May 30, 2017 (edited) I would consider that as I may be at the show. The transmission I have is in great shape otherwise. What would be your price. Would that transmission be a pre '65 that has shifting issues. Edited May 31, 2017 by Forge Farmer Share this post Link to post Share on other sites
oldredrider 2,553 #6 Posted May 31, 2017 Don't know the year but shifts great...solid gear shift action. Asking $100. Share this post Link to post Share on other sites
Forge Farmer 0 #7 Posted May 31, 2017 I may consider it. Thanks. Share this post Link to post Share on other sites
Racinbob 12,802 #8 Posted May 31, 2017 I might be able to help you out here. I need to check what I have. Stay tuned. 1 Share this post Link to post Share on other sites
Racinbob 12,802 #9 Posted May 31, 2017 Well, change to another channel. I thought for sure I had an extra cluster gear but no luck. Check with the other guys Steve mentioned. A good one shouldn't be hard to find. 1 Share this post Link to post Share on other sites
