RedRanger 1,470 #26 Posted May 30, 2017 1 minute ago, Tgtack said: I guess because it's mine and I really like it. Plus I like working on stuff. I do have a 1276, but that is not going to be a work tractor. I am pretty sure I can set up a right side pedal. Well if it's a project you want.... different story! I'd go with the hand brake mod. Share this post Link to post Share on other sites
squonk 45,552 #27 Posted May 30, 2017 22 hours ago, Ed Kennell said: OK, I'll mark that one up for you John. I admit, I have lost a few gray matter cells inhaling CO , but I never forget to pay my dues....and I owe you one. This could get ugly!!! I refuse to referee any skirmishes! I'll just stand in the back and heckle! 5 Share this post Link to post Share on other sites
wallfish 19,332 #28 Posted May 31, 2017 On 5/29/2017 at 9:01 PM, Tgtack said: Anyone know if the pedal is cast or forged? Makes a difference welding on it. Cast steel is different from cast iron. I'm no expert welder (not even a good one) but have had success welding the cast parts. Some of those parts are on the end of hydraulic rams and have held up since '08 A piece of steel can be fabricated to bolt on the pedal's tab instead of re positioning the tab to the bottom. Or a cast pedal from a 551 is set up with the tab on the bottom, or take a look at a 400 pedal which is made from bent steel, they also push on the rod. 1 Share this post Link to post Share on other sites
