Mt Zion 520H 43 #1 Posted May 26, 2017 Where's the best place to buy and cheaper price wise? Do i need to go by a specific model number or anything? No idea what i need to look for.. Any help appreciated. Also.. Read that front should be 1/8" lower than front. Does this need adjusting again if changing height from slot to slot of does it remian constant and only need done once? Share this post Link to post Share on other sites
woodchuckfarmer 333 #2 Posted May 26, 2017 Blades on the big bay. Copperhead ,3 blade set for a 48 inch deck. 29.95. Just got a set last week. Made in USA. Wayne Share this post Link to post Share on other sites
Jerry77 1,218 #3 Posted May 26, 2017 4 hours ago, Mt Zion 520H said: only need done once Correct. 1 Share this post Link to post Share on other sites
Aldon 4,828 #4 Posted May 26, 2017 Just make sure the deck blades don't have D type holes to mount. otherwise blade length is limiting factor... Share this post Link to post Share on other sites
Mt Zion 520H 43 #5 Posted May 27, 2017 16 hours ago, woodchuckfarmer said: Blades on the big bay. Copperhead ,3 blade set for a 48 inch deck. 29.95. Just got a set last week. Made in USA. Wayne Got a link perhaps? Can't seem to find them. Maybe i'm just stressed with other things going on. 16 hours ago, Jerry77 said: Correct. Thanks much brother. Seems after lifting 1 notch.. Mine seems off quite a bit so will need to correct that asap. Hadn't looked before because figured guy i got it from knew things and would have it right. Oh well. 14 hours ago, Aldon said: Just make sure the deck blades don't have D type holes to mount. otherwise blade length is limiting factor... Ok, will check on this too before ordering. Ty. Share this post Link to post Share on other sites
Jerry77 1,218 #6 Posted May 27, 2017 (edited) 1 hour ago, Mt Zion 520H said: Got a link perhaps Go here - lots of links - chk the numbers b4 you buy...on ebay - wheel horse 48 inch deck mower blades Edited May 27, 2017 by Jerry77 clarification Share this post Link to post Share on other sites
Mt Zion 520H 43 #7 Posted July 15, 2017 Haven't ordered yet.. Been side tracked a lot and still using dull blades. Grr.. Er.. Also going to need a skinny belt that connects the 3 blades to eachother as it snapped and then somehow the bigger belt dislocated from the center blades pulley. Smh. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,260 #8 Posted July 15, 2017 Garry Share this post Link to post Share on other sites
Mt Zion 520H 43 #9 Posted July 15, 2017 7 hours ago, gwest_ca said: Garry Is that the part number for the belt that connects the 3 blades? Share this post Link to post Share on other sites
Mt Zion 520H 43 #10 Posted July 15, 2017 (edited) Need belt asap so ordering is a route i'd like to avoid. Maybe tractor suply has a belt that would work? What size / length do i need? This one got cut up and think maybe a pc missing so can't go by it's length. Any help appreciated. Edited July 15, 2017 by Mt Zion 520H Add pic Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,260 #11 Posted July 16, 2017 The belt numbers and dimensions are on this page Garry Share this post Link to post Share on other sites
Mt Zion 520H 43 #12 Posted July 16, 2017 (edited) 21 minutes ago, gwest_ca said: The belt numbers and dimensions are on this page Garry Okay.. Is it possible the belt in there was the wrong size? It's a 1/4" belt that connected the spindles and the link you gave says 1/2" belts.. Edited July 16, 2017 by Mt Zion 520H Add pic Share this post Link to post Share on other sites
Mt Zion 520H 43 #13 Posted July 16, 2017 Picked up a belt from tractor supply.. Let's see how it works out. Not sure why previous owner put tbe 1/4" belt there.. Weird.. But it's corrected now. Share this post Link to post Share on other sites
Mt Zion 520H 43 #14 Posted July 17, 2017 (edited) So i found the oem toro blades on amazon for 35-46 bucks.. And i found 3 brands of blades on ebay... XHT brand clains to be best on market because it's made with MARBAIN and are harder and hold sharpness longer... Anyone have experience with them? I think i read elsewhere they tend to shadder if they fit something hard enough.. Not sure if should be concerned as there are times i hit harder than grass obejects.. Like rocks. Lol. Edited July 17, 2017 by Mt Zion 520H Add Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #15 Posted July 17, 2017 (edited) I have been using the STENS (bottom pic) brand lately and they're ok and have held up to gravel and a rock here and there, beware of the cheaper versions, but the TORO hold up the longest from my experience since 1998, Jeff. Edited July 17, 2017 by WVHillbilly520H Share this post Link to post Share on other sites
Mt Zion 520H 43 #16 Posted July 17, 2017 8 minutes ago, WVHillbilly520H said: I have been using the STENS (bottom pic) brand lately and they're ok and have held up to gravel and a rock here and there, beware of the cheaper versions, but the TORO hold up the longest from my experience since 1998, Jeff. Thank you brother; for info and pics. Much appreciated. 1 Share this post Link to post Share on other sites
Mt Zion 520H 43 #17 Posted August 5, 2017 Can anyone tell me exactly what size nut holds these blades on? Read different things different places about 1 1/8 , 1 1/4 and something like 16/18"... Don't have a socket big enough and don't want to be going back and forth with this. Also.. If using an impact gun... Do i need to lock the blade somehow or will it knock loose before blade goes ape****. Lol. Share this post Link to post Share on other sites
pfrederi 18,357 #18 Posted August 5, 2017 It is a 3/4" NF jam (thin) nut uses a 1-1/8th inch wrench. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #19 Posted August 5, 2017 3/4"-16 is the actual terminology of the thread size and technically it is a "jam" nut not a standard nut and requires an 1 1/8" socket or wrench 6 point preferred over 12 pt and if using an impact wrench to remove no blocking should be required but a rag over the blade or a gloved hand to hold it still while the impact is hammering it loose, Jeff. Share this post Link to post Share on other sites
Mt Zion 520H 43 #20 Posted August 5, 2017 Okay thanks. Best way is 1 1/8" wrench and long pipe for leverage or impact with 1 1/8" socket? I read using a block of wood between blade and deck to keep from spinning helps.. But will this work if using impact? Thanks WVHillbilly520H; much appreciated brother. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #21 Posted August 5, 2017 2 minutes ago, Mt Zion 520H said: Okay thanks. Best way is 1 1/8" wrench and long pipe for leverage or impact with 1 1/8" socket? I read using a block of wood between blade and deck to keep from spinning helps.. But will this work if using impact? For me the air powered impact wrench with 6pt socket works best but if that is unavailable, useing wood block and standard wrench but "tapping/whacking" the wrench with a rubber mallet is like the same effect as the impact wrench too loosen the nuts then spin them off as normal, Jeff. Share this post Link to post Share on other sites
Mt Zion 520H 43 #22 Posted August 5, 2017 36 minutes ago, WVHillbilly520H said: For me the air powered impact wrench with 6pt socket works best but if that is unavailable, useing wood block and standard wrench but "tapping/whacking" the wrench with a rubber mallet is like the same effect as the impact wrench too loosen the nuts then spin them off as normal, Jeff. I have an 18volt Milwaukee 1/2" impact my pops gave me as a bday gift. Haven't used yet.. It should do the job right? Lol. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #23 Posted August 5, 2017 Just now, Mt Zion 520H said: I have an 18volt Milwaukee 1/2" impact my pops gave me as a bday gift. Haven't used yet.. It should do the job right? Lol. Give it a whirl, some of those electric impacts are real decent some aren't so much, but like I said above if you can't get them broken loose with the impact there's the rubber mallet/wrench method,Jeff. Share this post Link to post Share on other sites
Mt Zion 520H 43 #24 Posted August 6, 2017 So the impact worked easy peasy. Now.. What's the torque spec to put them nuts back on? Lol. Don't wanna torque gun em on and damage anything. Share this post Link to post Share on other sites
EricF 589 #25 Posted August 6, 2017 Tighten them nice and snug by hand with a wrench; the torque spec is 90-100 ft-lbs or so. They tend to tighten up more due to the rotation of the blades. Share this post Link to post Share on other sites
