dlaw90 14 #1 Posted May 20, 2017 I rolled my 1999 314-8 out today to grease the zerks. While i was rolling it, i heard the sound of metal on metal rubbing. It looks like the sound is coming from the brake drum. I checked the brakes according to manual and the brake adjustment needed to be tightened. I tightened it, but the rubbing noise is still there. Is there anything else I should check? Transaxle fluid is full and looks clean. This is my first tractor so no answer is too obvious Share this post Link to post Share on other sites
953 nut 62,512 #2 Posted May 20, 2017 You may want to jack it up and remove the left rear wheel to inspect the brake band. If the lining on the band is bad you can buy a replacement band lining from @rmaynard, top quality and reasonably priced. 4 Share this post Link to post Share on other sites
jeff lary 173 #3 Posted May 20, 2017 some good information on here quite often,.. glad I check in. 2 Share this post Link to post Share on other sites
dlaw90 14 #4 Posted May 22, 2017 On 5/20/2017 at 1:36 PM, 953 nut said: You may want to jack it up and remove the left rear wheel to inspect the brake band. If the lining on the band is bad you can buy a replacement band lining from @rmaynard, top quality and reasonably priced. Thanks for the help. I just ordered a replacement lining 1 Share this post Link to post Share on other sites
rmaynard 16,623 #5 Posted May 22, 2017 1 hour ago, dlawrence529 said: Thanks for the help. I just ordered a replacement lining Thanks for the order Dale. The lining is going to the post office this morning. 3 Share this post Link to post Share on other sites
dlaw90 14 #6 Posted May 22, 2017 2 hours ago, rmaynard said: Thanks for the order Dale. The lining is going to the post office this morning. Thanks Bob. I'm also interested in your lug nut kit. Do the new bolts simply thread into the hubs from the backside? Are there any downsides to converting to lug nuts (less strength, interference with some wheel weights, etc)? 1 Share this post Link to post Share on other sites
rmaynard 16,623 #7 Posted May 22, 2017 Have not had any reports of a "downside"" Yes, they just thread in from the back. Some hubs require the removal of the square-head set screw and jam nut until the one bolt that conflicts is installed. 2 Share this post Link to post Share on other sites
dlaw90 14 #8 Posted May 22, 2017 Thanks again Bob. Just ordered a set of the lug nuts Share this post Link to post Share on other sites
