SadieCoonhound 8 #1 Posted May 14, 2017 I need to remove the intake manifold to clean the carb. Will I have to remove the muffler? I'd like to order all the gaskets before I start this. its an Onan P220. Would appreciate a source on where to order parts from. Thanks. Share this post Link to post Share on other sites
woodchuckfarmer 333 #2 Posted May 14, 2017 Ive taken my carb off with out removing the intake manifold. Its tight but it can be done. Share this post Link to post Share on other sites
SadieCoonhound 8 #3 Posted May 14, 2017 The bolts are on the bottom of the carb. What are you suggesting? Share this post Link to post Share on other sites
woodchuckfarmer 333 #4 Posted May 14, 2017 Ive got a wrench bent up at an angle to slide under the carb and turn the nuts . 1 Share this post Link to post Share on other sites
SadieCoonhound 8 #5 Posted May 14, 2017 I'm assuming a long l-shaped box end. Going to give it a try. I thought the bolts would be to long to come out from the bottom. Thanks Share this post Link to post Share on other sites
woodchuckfarmer 333 #6 Posted May 14, 2017 I think there about 1 inch long. Share this post Link to post Share on other sites
SadieCoonhound 8 #7 Posted May 14, 2017 Thanks. Worth a try. Share this post Link to post Share on other sites
boomers_influence 106 #8 Posted May 14, 2017 sadie the length of the carb to manifold bolt will depend on the spec letter of the engine. spec A-B 1" to 1 3/8 " X 5/16 spec C and beyond 1 3/4" to 1 7/8" X 5/16 thank you. boomer ( the used onan engine parts guy, also NOS and new ) 1 Share this post Link to post Share on other sites
Cee245 852 #9 Posted May 16, 2017 @woodchuckfarmer , can you post a pic of your wrench? Thanks ~C Share this post Link to post Share on other sites
woodchuckfarmer 333 #10 Posted May 16, 2017 not good with picts sorry Share this post Link to post Share on other sites
SadieCoonhound 8 #11 Posted May 16, 2017 Can someone suggest where I can order intake manifold and carb gaskets? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,975 #12 Posted May 16, 2017 Boomer usually chimes in. This is likely a contact for him http://boomersonanparts.com/ Garry Share this post Link to post Share on other sites
SadieCoonhound 8 #13 Posted May 17, 2017 Funny. I spoke with him and am ordering parts. Thanks. Share this post Link to post Share on other sites
SadieCoonhound 8 #14 Posted May 21, 2017 Cee The onan service manual says the card can be removed with a crows foot wrench. Or a short 1/2 inch open end. I did it the long way. Removed the muffler, heat shields, etc. Read the manual too late. 1 Share this post Link to post Share on other sites
