BigRed84 65 #1 Posted May 9, 2017 I assumed I could find tons of info searching the typical best and biggest and all that, but I was surprised there wasn't too much info specifically relating to my tractor. Is there anyone that has first hand experience with the 314-H (or -8...I assume trans doesn't change tire sizes). Currently the tires on my tractor are 23 x 9.50 -12. Since I don't use it to cut the grass anymore, i'll be using it strictly to work in the garden, haul the cart around the yard, and snow blow in the winter, I think the Carlisle tru-power bar lug design should do well. They only seem to be 10.50 width. Does anyone know, or have first hand experience for fitment on a 314? (without modifying axle hub or fenders) Share this post Link to post Share on other sites
pfrederi 19,933 #2 Posted May 9, 2017 I have them on my 310-8 which should have the same fender clearances as your 314. Note how much wider they are than the deestones of the same size 2 Share this post Link to post Share on other sites
Jerry77 1,218 #3 Posted May 9, 2017 If you use the 10.50 and then put chains on them, the chains will likely hit the posts that hold the brake lining on.. I had that problem and had to alter the brake posts for clearance..the chains will come very close to the cooling fan for the tranny too....just my 2 Share this post Link to post Share on other sites
farmer 1,081 #4 Posted May 9, 2017 I don't have experience of the Carlisle tru power tyre, but I would say that if you intend to use a plough in your garden, (say a 10" Brinley) go for 23x 8.50 -12 rears. Brand really doesn't make much difference, but width does. 3 Share this post Link to post Share on other sites
BigRed84 65 #5 Posted May 9, 2017 WOW!! Thanks for the pic...that almost looks too wide for what I was expecting. Both of those tires in the comparison photo are labeled as 10.5?? That does bring me to another question then....My main use for the tractor will be garden work, hauling a semi-heavy cart around, eventually I would love to have a plough set up, and snow blowing the paved driveway and path down to my wood shed which is on grass and hills. Maybe a narrower tire would be better? I'm confused, all my knowledge of tires comes from the mud tires I get for my jeep and truck, and the concept was always wider being better for off road use, narrow being better for snow. True for tractors as well? I don't think the 314 has a locking diff right? (one tire-fire if I started spinning?) Share this post Link to post Share on other sites
roadapples 6,987 #6 Posted May 9, 2017 Narrow tires and chains for snow... Share this post Link to post Share on other sites
Achto 31,042 #7 Posted May 9, 2017 You could drop to a 23-8.50x12 Carlisle, you will only loose an inch of width and if you wish to use a mold board plow it will fit a little better in the furrow. Just my opinion. Or the Deestone 10.50's are actually closer to 9.50 in width if you wish to stay close to original. 1 Share this post Link to post Share on other sites
BigRed84 65 #8 Posted May 10, 2017 So if the Carlisle 10.50 is that much wider than the Deestone....would it be safe to say the Carlisle 8.50 runs slightly wider than advertised as well? I measured the turf tires I have on there now. Advertised as 9.50....the tread themselves only measures 9"....i can see 9.50 if I measure straight out from sidewall to sidewall but i didn't think that was the accurate measurement. I definitely didn't want to lose any height either so if the Deestone runs small on height as well as width I might stick with the 23 x 8.50 from Carlisle. Thanks for the advice fellas. 1 Share this post Link to post Share on other sites
RandyLittrell 3,944 #9 Posted May 10, 2017 For most tires the width equals section width which is overall. Side wall to side wall. I would go with the 23x8.50 as well. Randy Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #10 Posted May 10, 2017 These Nanco 23x10.50-12 Ags I bought run right at 9.50 wide mounted and inflated, might be exactly what you want I'm very satisfied with them, Jeff. Share this post Link to post Share on other sites
BigRed84 65 #11 Posted May 10, 2017 I might just go with the Carlisle 23x8.50 and figure out if its too narrow once I have them. Has quality of Carlisle gone down since they are made in china now? Not sure how accurate that info is but that's what several searches turn up when I look. Does WH forum have a preferred tire vendor so I can order a set? Share this post Link to post Share on other sites
pfrederi 19,933 #12 Posted May 10, 2017 (edited) Yes both tires in my picture are 23 10.50 x12 Deestones run small. Also you have an open differential it will spin one wheel. (That is why I converted the 310-8 in my pictures to a 10 pinion limited slip) As to China and quality...try to find a small tire NOT made in China anymore. Edited May 10, 2017 by pfrederi Share this post Link to post Share on other sites
BigRed84 65 #13 Posted May 10, 2017 2 hours ago, pfrederi said: As to China and quality...try to find a small tire NOT made in China anymore. Yea I was afraid that was going to be the answer. It's a shame how much the U.S.A. has unloaded for cheap labor overseas...but that's a whole different topic. haha Thanks again for all the info, i'll post up pics if I decide to go with the 23x8.50 Carlisle. Share this post Link to post Share on other sites
aHorseofCourse 261 #14 Posted May 10, 2017 My tru powers were made in USA. Some of their smaller tires are made in china Share this post Link to post Share on other sites
classicdmax 190 #15 Posted May 10, 2017 (edited) I just order me a set of 23-10.50-12 off amazing, they had the best price 10 hours ago, pfrederi said: (That is why I converted the 310-8 in my pictures to a 10 pinion limited slip) Sorry to get off topic, I'd love to do this to my tractor. J imagine it greatly increases traction. How does it affect turning? Edited May 11, 2017 by classicdmax Share this post Link to post Share on other sites
pfrederi 19,933 #16 Posted May 11, 2017 12 hours ago, classicdmax said: I just order me a set of 23-10.50-12 off amazing, they had the best price Sorry to get off topic, I'd love to do this to my tractor. J imagine it greatly increases traction. How does it affect turning? It is not a locking differential merely a ltd slip. I see no impact on steering. Mine was an 8 speed. Ihave to think a bit about doing the swap in a later model hydro (the older Sundstrand hydos Chargers/Electros used the 10 pinion so it may be possible. Share this post Link to post Share on other sites
