Fordiesel69 271 #1 Posted May 8, 2017 Early 90's 416-8 w/ unidrive 8 speed. Pulled the dipstick and it is rusted pitted, and the fluid is very milky. I am aware on how to flush with kerosene, refill and replace shift boot, but without taking it apart, would this thing last? My thought is the bearings are prob already rusted. Share this post Link to post Share on other sites
stevasaurus 23,536 #2 Posted May 8, 2017 I think you already know what I have to say about that? Suppose you decide to flush it numerous times and you do have some bad bearings. Flushing is not going to fix those, and you could easily do more damage and make it more costly if you go that way and drive it. There is only one good reason to flush a transmission...it makes it a much cleaner job to open up. 5 Share this post Link to post Share on other sites
Genuine1979 5 #3 Posted July 20, 2018 (edited) Hey Fordiesel69, Hello. I am working watery fluid real time. How far up on the stick is the pitting? If it is in the normal above the "case line" then try flushing only. Spin the tires slowly in gear from input shaft. If you feel any resistance, I would flush once more and split the trans. Sludge alone is enough to mess up shifting Hi/Lo and R/4 in my case along with worn input gears(not exactly sure of the actual name of the gear, not using a book). My issue here was wouldn't go into gear, any gear. Used a small file to straighten out gears and about to put it back together once I replace the lil' ball bearing I just lost if I can not find it with the magnet. What I found insde this one is surface rust inside the case at the very top of the case. I purposely placed a piece of gasket in the input gears and everything stopped could not spin anything by hand and I have all gears out except the first input gear and the next one. I can try to put pics on here if that will help... My apologies on the vagueness but once again, I am currently working on this trans. thegenuinenewguy Edited July 21, 2018 by Genuine1979 New thought. Share this post Link to post Share on other sites
Cee245 850 #4 Posted July 22, 2018 @Fordiesel69, I have rebuilt a 1991 416-8 Unidrive transmission. I had to replace shift forks and 2nd or 3rd gear. I really didn't think it was too hard especially with a manual or a drawing from toro.com as I used. Good luck Cory Share this post Link to post Share on other sites
953 nut 63,618 #5 Posted July 22, 2018 @Genuine1979, You may want to start a new post in this category. You will be able to generate a lot more input that way. http://www.wheelhorseforum.com/forum/49-transmissions-and-transaxles/ The post below will be helpful to you. 2 Share this post Link to post Share on other sites
oliver2-44 11,149 #6 Posted July 22, 2018 O....there aut-ta-be a song ......water in my transmissin O....water in my oil O....what a rusty sludgee mess it is O..... that’s all I got 1 1 Share this post Link to post Share on other sites
