Zeek 2,299 #1 Posted April 30, 2017 I read the threads related to shipping via Fastenal and it seems like it will work. Question: If you have sent or received a full tractor, can you tell me how it was secured to the pallet securely without screwing it up? Pics would be awesome. I may ship a fully restored tractor and I don't want to scratch the axle housings with straps. Thanks. Share this post Link to post Share on other sites
Digger 66 3,523 #2 Posted April 30, 2017 (edited) I've seen them banded around the tire with 5/8" plastic banding much like an auto recovery operation secures cars to rollbacks . Bonnets I think they're called . Edited April 30, 2017 by Digger 66 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,603 #3 Posted April 30, 2017 4 Share this post Link to post Share on other sites
Shynon 7,522 #4 Posted April 30, 2017 Never shipped one, but I would strap all four tires to the pallet, thus only touching the rubber. That is how I strap them in my enclosed trailer. Share this post Link to post Share on other sites
wh500special 2,371 #5 Posted April 30, 2017 I've sent several via fastenal and haven't had any complaints. I use ratchet straps and hook them into the holes on the front of the frame-to-transaxle mounting plate to hold the tractor for side-to-side stability. The other strap goes on the hitch, under the pallet, and up around the front to the front axle. I think if I had one o had to worry about not scratching on the front I'd lasso around the front tires. Then I stretch wrap the whole thing to keep prying eyes and fingers out. Block the tires of course. Steve Share this post Link to post Share on other sites
Zeek 2,299 #6 Posted April 30, 2017 All good suggestions! The tires never occurred to me for some reason . . . Thanks for the pics Steve! Share this post Link to post Share on other sites
953 nut 63,780 #7 Posted April 30, 2017 12 minutes ago, Zeek said: All good suggestions! The tires never occurred to me for some reason . . . Thanks for the pics Steve! I think it would be a good idea to partly deflate the tires prior to strapping the tires so the strap can't slide off the side. 2 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,603 #8 Posted May 1, 2017 I am sure they told you but all the fluids are suppose to be drained. Not sure if they check the tranny? 1 Share this post Link to post Share on other sites
WHX?? 54,103 #9 Posted May 1, 2017 Can you leave the battery in it? Share this post Link to post Share on other sites
