Al C. 1,474 #1 Posted April 16, 2017 At the end of last fall, I drained the fuel from my two Wheel Horses and ran them dry. Last week I filled the 1067 with gas and it started right up. Yesterday I fill the SK-486 with gas and turned it over. After 20 minutes and multiple attempts, it was clear no gas was getting to the engine. I disconnected the gas line at the fuel pump, sure enough, it was dry. Long story short, out of frustration I blew into the fuel tank to force gas through the line. It worked! It primed the pump and the tractor started on the first turn. It is running great! I can't image that blowing into the fuel tank is a "recommended" solution. The next time this happens, what is a better way to fix it! 2 Share this post Link to post Share on other sites
rjg854 13,087 #2 Posted April 16, 2017 Just a guess, maybe leave the gas cap either loose or just take it off? Maybe a venting problem? 1 Share this post Link to post Share on other sites
953 nut 66,664 #3 Posted April 16, 2017 That is a problem with rear mounted fuel tanks. I have mounted an electric fuel pump low on the frame and had no more problem. 5 Share this post Link to post Share on other sites
SylvanLakeWH 31,557 #4 Posted April 16, 2017 I have done that on numerous occasions. Wipe it off and blow steady..Works every time! Just remember to breath OUT when you have your mouth around the filler hole!!! 2 Share this post Link to post Share on other sites
scotty 252 #5 Posted April 16, 2017 (edited) I put on one of those in line hand primer pumps they work pretty good. Like this. Just make sure you get the right size for your fuel line. http://www.ebay.com/itm/like/182005970824?lpid=82&chn=ps&ul_noapp=true Edited April 16, 2017 by scotty 8 Share this post Link to post Share on other sites
JC 1965 1,546 #6 Posted April 16, 2017 55 minutes ago, 953 nut said: That is a problem with rear mounted fuel tanks. I have mounted an electric fuel pump low on the frame and had no more problem. I agree. I put electric fuel pumps on all three of my horses. Works great. 2 Share this post Link to post Share on other sites
cleat 8,987 #7 Posted April 16, 2017 17 minutes ago, scotty said: I put on one of those in line hand primer pumps they work pretty good. Like this. Just make sure you get the right size for your fuel line. http://www.ebay.com/itm/like/182005970824?lpid=82&chn=ps&ul_noapp=true I put hand primers on all 4 of my 520's and after a few quick squeezes they start right up. Even worked great after sitting all winter. 3 Share this post Link to post Share on other sites
clueless 3,405 #8 Posted April 16, 2017 5 hours ago, cleat said: I put hand primers on all 4 of my 520's and after a few quick squeezes they start right up. Even worked great after sitting all winter. Where in the fuel line did you put your primers? Also is the one on ebay listed here the one you used? Share this post Link to post Share on other sites
doc724 927 #9 Posted April 16, 2017 Unlike Al, I leave fuel treated with Seafoam in all the tanks of my machines. Of the 4 machines, only my C141 is difficult to start after sitting for 3-4 months. This year, after reading the posts about electric fuel pumps, I simply filled the tank full before I tried to start it. Although it took maybe 20-30 seconds of cranking to get gas flowing, it did start. My newer machines 314, 416 and 5xi, started within 5-10 seconds of cranking. Although electric pumps are a good solution, I think the root cause is that maybe 30 year old fuel pumps just may be beyond their intended design life. Also, the chinese built replacement pumps may not have as robust materials as the original OEM pumps of the 60's and 70's. 1 Share this post Link to post Share on other sites
cleat 8,987 #10 Posted April 16, 2017 5 hours ago, clueless said: Where in the fuel line did you put your primers? Also is the one on ebay listed here the one you used? I put them just before the fuel pump. Yes, I bought cheap ones off of ebay straight from China. If these fail but I like them (I think I will) then I will buy better ones. Share this post Link to post Share on other sites
gregg'shorses 77 #11 Posted April 16, 2017 I found the marine primer bulbs although a lot more money are worth the extra The ones I have bought were made in the USA . . http://www.autozone.com/miscellaneous-non-automotive/boat-primer-bulb/valmar-marine-5-16-in-high-output-primer-bulb/294521_0_0 http://www.oreillyauto.com/site/c/detail/SIE0/188002EP1/N2686.oap?ck=Search_N2686_-1_-1&pt=N2686&ppt=C1980 Share this post Link to post Share on other sites
Al C. 1,474 #12 Posted April 17, 2017 I want to thank everyone for their ideas/experience. Especially, SylvanLake, thanks for admitting you've tried the same solution I used. Now that I know this is a problem others have had, and since it happens so infrequently, I'm going to try to construct a reusable diaphragm to put over the filler hole and pressurize the tank by pushing on it. I just have to find a material the will not "recoil". I'll put out a post if I'm successful. Thanks again!!!! 3 Share this post Link to post Share on other sites
DennisThornton 4,773 #13 Posted April 17, 2017 I've seen where 1/2 wouldn't start but a full tank would. 2 Share this post Link to post Share on other sites
Al C. 1,474 #14 Posted April 17, 2017 I'm guessing the minimal weight of the additional fuel creates just enough pressure to force gas through the line and get things flowing. So obviously, it doesn't take much. 3 Share this post Link to post Share on other sites
thehorse 221 #15 Posted April 18, 2017 I think a better solution is to a have a buddy over and after he has a couple of beers, have him blow into the tank! Lol 4 Share this post Link to post Share on other sites
c-series don 11,963 #16 Posted April 19, 2017 I took an old fuel cap,broke off the non working float and installed a simple tire valve in the center of the cap. Now I can just thread that cap on any of my tractors and give it a quick shot of air and walla! Running tractor. It doesn't take much just a few psi, as most of us know that have used the "I'll just man up and blow into the tank" technique!!! 4 Share this post Link to post Share on other sites
Al C. 1,474 #17 Posted April 19, 2017 This is one reason I like this forum - common sense rules! Great idea! Share this post Link to post Share on other sites
Lee1977 7,645 #18 Posted April 19, 2017 I'm cheap I have plastic bottle with a spout. If my 312 doesn't start after two short tries. I pull the breather and give it a couple shots of gas. It will pull the gas up once it is running. 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,575 #19 Posted April 20, 2017 Interesting and some funny comments by all. Glenn Share this post Link to post Share on other sites
fitter 4 #20 Posted April 28, 2017 This sounds like a design flaw. Last year I relocated after market electric fuel pump down low under tank on my 416-8 with a primer bulb with new fuel filters and would run good most of the time but would still die from lack of gas occasionally. Now I just started cutting the grass for the first time this year and it will die after 2 minutes of run time.Re prime and start over and over. What is the real solution here? Seems like there are way to many fuel issues of this kind. Share this post Link to post Share on other sites
formariz 12,378 #21 Posted April 28, 2017 On 4/17/2017 at 9:29 PM, thehorse said: I think a better solution is to a have a buddy over and after he has a couple of beers, have him blow into the tank! Lol Make sure you have alcohol resistant fuel lines before you allow him to blow into tank! Share this post Link to post Share on other sites
fitter 4 #22 Posted April 28, 2017 Just replaced after market fuel pump and all is good...for now. 2 Share this post Link to post Share on other sites
