HorseFixer 2,013 #126 Posted April 29, 2017 Looks like the Weather is not going to Cooperate the next couple days most especially for running electrical wiring underground plus working on electricity, So I guess I will be back on fabrication tomorrow. We had two storms that missed us but there is one brewing out west heading straight for us! Share this post Link to post Share on other sites
HorseFixer 2,013 #127 Posted April 29, 2017 Today worked on the Bucket and got it put together. Will add a knife blade on the bottom to save the edge and will add 1/2" Material to the Top to stiffen up the Bucket so I can put a GRAB HOOK to pick things up. I think I will take a Break for a bit and go out to Rural King and see what kind of hooks they have. I also need to install the Bucket Brackets and fit them in place. Here are some Pics. 9 2 Share this post Link to post Share on other sites
woodchuckfarmer 333 #128 Posted April 29, 2017 Looking good Duke. Wayne 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #129 Posted April 30, 2017 Duke, I had 3/8" grab hooks welded to my bucket before they delivered it, on eBay they go for $9/pr and on my Kioti it came with a 4" D ring welded in the center it does OK but I prefer the outward grab hooks all 3 would be better, Jeff. 4 Share this post Link to post Share on other sites
HorseFixer 2,013 #130 Posted April 30, 2017 Jeff I Like your thinking. And I think I came up with a very Similar Solution but even better. I can't let the Cat outta the bag just yet but maybe late tomorrow I will have it all together 1 Share this post Link to post Share on other sites
Snowmobileaddict 403 #131 Posted April 30, 2017 Duke, Its so cool to see the parts you had cut from the CAD file I provided. I hope that you are able to make good use of them. What am I saying...With that arsenal of tools in your shop (very envious!!!), you'll get it together. Looking at what you're working with, I sometimes wonder how I got my build done...A borrowed 220V MIG welder set up for flux core because I didn't want to lug the bottle back to my place from my dads shop, a grinder and a lot of careful measuring for cuts done by a third party. Those welds on your bucket look primo. I wouldn't want to put mine into service if my work looked like that! I'd be afraid I mess it up! -Andy 4 Share this post Link to post Share on other sites
HorseFixer 2,013 #132 Posted May 1, 2017 Andy Yes I appreciate that Cad File thank you again. I thought I would work on the BIG STUFF first that being the bucket before I get into the frame and so forth. Well today I was cut short 1/2 the day because the Power went off in my City due to someone hitting a Transformer or something. Anyways a weak point on many of these buckets are the top edge is Flimsy. As we talked about putting some hooks and stuff for lifting things I Integrated that into my design I didn't want the stiffners to be on the outside so I put them to the TOP Inside. I used a 1/2 X 3 piece if flat stock with a 1/2" X 1" pice and made my own Angle Iron so to speak. I cut 2 more pads of 1/2" X 4" material X 3 and used them where the Hooks and Rings will be. I welded it all together and hit the Drill Press and drilled 3 3/4" Holes for the Clevis Pins. Now of I want the Hooks on the outside no problem. If I want Rings on the outside and a Hook in the Center No Problemo. If I want to flip the hooks over I can do that too. I might to be able to make other attachments for it later. So what do ya think will that get the Job Done? 7 Share this post Link to post Share on other sites
farmer 1,078 #133 Posted May 1, 2017 Nicely done and strong around your lifting points, by the way, is it just coincidence that all the power goes out in your city around the same time you installing solar arrays and laying cables. You may be interested in one further addition I added to my bucket that I recommend you think on, I'll include it tonight. 3 Share this post Link to post Share on other sites
MalMac 1,332 #134 Posted May 1, 2017 Duke, are you going to put a "gusset" on the bottom of the bucket to where it joins the back wall of the bucket? The 550 had it. It will not just strengthen it but also aid in a more cleaner dump of the bucket. 1 Share this post Link to post Share on other sites
HorseFixer 2,013 #135 Posted May 1, 2017 (edited) 10 hours ago, farmer said: by the way, is it just coincidence that all the power goes out in your city around the same time you installing solar arrays and laying cables. You may be interested in one further addition I added to my bucket that I recommend you think on, I'll include it tonight. Thanks, And Brother Farmer I didn't mention this but guess I will now. When I have a Power Outage I Usually go out in the RV and start the 6500W Onan Generator and plug it in a 20 amp Outlet on the side of the house 20 ft away. And run all my critical Systems. Well guess what? Gen wont start! And by the way my enphase Solar system shuts off when Power goes off by NEC Standards so I don't fry the utility worker on the power lines. (My System doesn't have Batteries or Invert-er). So now I have a Generator to Fix!!!!!!! The kitchen hood fan quit working, And the wife says the dishwasher has a leak! WTF else can go wrong! 6 hours ago, MalMac said: Duke, are you going to put a "gusset" on the bottom of the bucket to where it joins the back wall of the bucket? The 550 had it. It will not just strengthen it but also aid in a more cleaner dump of the bucket. Tim, I had planned on installing two of them. Since my Bucket is narrower by 7 inches I prolly wouldn't even need any, but for they don't take any room so why not? Edited May 1, 2017 by HorseFixer 1 Share this post Link to post Share on other sites
roadapples 6,983 #136 Posted May 1, 2017 I would have thought your solar system would have a transfer switch like a standby generator. That way utility workers would be safe... 1 Share this post Link to post Share on other sites
HorseFixer 2,013 #137 Posted May 1, 2017 6 minutes ago, roadapples said: I would have thought your solar system would have a transfer switch like a standby generator. That way utility workers would be safe... I don't have that kind of a system, and most people don't anymore. The Battery and Invert-er type System is OLD TECHNOLOGY, Requires alot of maintenance and replacement Parts to maintain. Sure you get the convenience of power during a power outage but in my home town it doesn't happen that often. And like I say I do have the RV for back up normally but I have a plugged fuel line (that's what I found yesterday) NO WAY will a Solar System Run a Welder 5hp Compressor and all I do in my shop and house anyways. With a Battey and Inverter type system you have to watch your power consumption. 2 Share this post Link to post Share on other sites
HorseFixer 2,013 #138 Posted May 3, 2017 (edited) Decided to put only (1) Gusset inside the bucket for support as two would be WAY OVERKILL. Internally welded all seams on the inside of the bucket and installed the bucket brackets. The next step will be to install gussets to the bucket brackets for support. I have a 1/2" X 4" Wide X 48" Long Knife edge for the Bucket ordered for the leading edge of the Bucket. That will be here Monday. Have plenty of brackets and parts to weld so there is no loss for work that's for sure. Edited May 3, 2017 by HorseFixer 7 1 Share this post Link to post Share on other sites
woodchuckfarmer 333 #139 Posted May 6, 2017 Looking good Duke. Red paint will be flowing soon. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #140 Posted May 6, 2017 Duke, you know all the "cool kids" are doing the bare metal flat clear these days on their high $ builds, but seriously looking good I would be torn between epoxy based paints and Powdercoating for the bucket boom arms and sub frame assembly, Jeff. 1 Share this post Link to post Share on other sites
HorseFixer 2,013 #141 Posted May 16, 2017 Switched Gears Sorry Out Of The Shop For A Few Days! Share this post Link to post Share on other sites
Thor27 832 #142 Posted August 19, 2017 Duke, Just wanted to say this is a great informative build. Hope your feeling better and back at this soon! Share this post Link to post Share on other sites
Pullstart 66,021 #143 Posted February 14, 2020 I have contacted Duke a couple different ways to see about purchasing this project, as it is still active in the classifieds. I don’t see any subframe info here, or if any subframe was in Duke’s original deal. I didn’t know if he was modifying one, or building one at some point. Does anyone know who this was purchased from, if they are a forum member that might shed any light on this portion of the project? I am not sure what tractor this would go on. If it was truly a quick attachment (less than a few hours) I might consider Hot Wheels or Frank as my best options. Imagine either one of those machines with a loader and possibly a subframe that might support a ‘hoe? I hope to hear back from Duke soon Share this post Link to post Share on other sites
Shynon 7,477 #144 Posted February 14, 2020 @stevasaurus maybe he can help? 1 Share this post Link to post Share on other sites
Pullstart 66,021 #145 Posted February 14, 2020 Tom, Steve got me a different phone number for Duke. I’ll try to call him this evening. Thanks fellas! Share this post Link to post Share on other sites
Pullstart 66,021 #146 Posted February 15, 2020 @stevasaurus I called, but it was the same number I already had. It was turned off / straight to a generic greeting unfortunately. I left a message and hope to hear back. @HorseFixer If you’re out there... give me a holler. Hope all is well with ya! Share this post Link to post Share on other sites
Pullstart 66,021 #147 Posted February 18, 2020 I heard back from Duke tonight. He’s out of town for a bit but I might be second in line still. Either way, it’s good to hear that all’s well in his world 2 1 Share this post Link to post Share on other sites
Pullstart 66,021 #148 Posted August 24, 2020 I have scoured this thread so many times, it’s not funny! @HorseFixer did a great job documenting things, but there seem to be many pictures missing from @Snowmobileaddict’s posts. I should be able to thumb through the majority of the thread and get what I need to get this mounted to my new 520XI! I never did update this, I made the deal with a Duke back in May of this year. Once I catch up on some needed projects like a hauler and plow truck, it’ll be back to this build. I can’t wait to finish it in the way that Bob intended! Share this post Link to post Share on other sites
Pullstart 66,021 #149 Posted March 27, 2021 It’s been a while... Sizing things up. 2 Share this post Link to post Share on other sites
Pullstart 66,021 #150 Posted March 27, 2021 Here’s a bit of a re-introduction video... 1 3 Share this post Link to post Share on other sites
