KrazeyOlDave 860 #251 Posted May 30, 2021 Any updates? I hope you’re doing well, I look forward to seeing it completed. Share this post Link to post Share on other sites
Pullstart 71,267 #252 Posted May 30, 2021 4 hours ago, KrazeyOlDave said: Any updates? I hope you’re doing well, I look forward to seeing it completed. Thanks for the bump. I have not touched this in a while. I need to finish welding some stuff that’s torn apart, clean and paint, then find and assemble hydraulic lines. Unfortunately, life has been too busy for much tractor work. 3 1 Share this post Link to post Share on other sites
Pullstart 71,267 #253 Posted October 1, 2022 It’s been too long! 1 Share this post Link to post Share on other sites
Pullstart 71,267 #254 Posted October 1, 2022 I need to cap the bumper, then this piece is complete! Why have I waited so long? 2 Share this post Link to post Share on other sites
Pullstart 71,267 #256 Posted October 1, 2022 The subframe was mostly done! I’d like to go through the build a bit and make sure I’m ready to cap the main 2” tubes. It seems like I left the rear long. I might cap the front, then do one last fit up before painting. 1 Share this post Link to post Share on other sites
Pullstart 71,267 #258 Posted October 21, 2022 It’s been a while since this was rolling on aired up tires! I figured that after all the welding, and lost time, I should do another fit up. Share this post Link to post Share on other sites
Pullstart 71,267 #259 Posted October 21, 2022 Subframe and loader tower are on. The tower went into place much easier when I realized the cables were pinched between the bumper and the battery tray! 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #261 Posted October 21, 2022 I like what you said looks aren’t important function is and looks good great job Kevin Kollin 1 Share this post Link to post Share on other sites
Pullstart 71,267 #262 Posted October 22, 2022 I did some measuring today. The soft hoses would allow more serviceability over the years I suppose. I’m not 100% keen on them, but it is what it is. 1 Share this post Link to post Share on other sites
Pullstart 71,267 #263 Posted October 22, 2022 Before I pull the trigger, I need to do some other figuring and planning. But this is way cheaper than the local farm store! 1 1 Share this post Link to post Share on other sites
Pullstart 71,267 #264 Posted October 24, 2022 By eliminating some fittings and making the crossover hoses direct to the cylinders, I’ve reduced cost drastically. @JoeM I know you have hoses on your FEL. Any reason to shoot down my revised list? Share this post Link to post Share on other sites
Pullstart 71,267 #266 Posted October 24, 2022 @JoeM I see that you had dedicated hoses at some point. Any regerts? 1 Share this post Link to post Share on other sites
Pullstart 71,267 #267 Posted October 24, 2022 (edited) @cschannuth I scanned through your build and found @WHX??’s 520H loader tractor has the same hose configuration. No fittings on the left side, just from the tee on the right direct to the cylinders. Anything you would have changed? Was it good that way? Edited October 24, 2022 by Pullstart Photos Share this post Link to post Share on other sites
cschannuth 3,821 #268 Posted October 24, 2022 3 hours ago, Pullstart said: Anything you would have changed? Was it good that way? It was fine that way but I would’ve preferred hard lines for the main run out with short hoses to the cylinders. Share this post Link to post Share on other sites
Pullstart 71,267 #269 Posted October 24, 2022 (edited) Thanks to @JoeM, I ordered my hoses and fittings from Surplus Center, instead of Hydraulic Hoses. There was a significant savings on each item, enough so that I was able to add a 2” sleeve to the order, so I can bundle all the hoses together on the loader frame. Woo hoo! The difference was $233.76 including tax and shipping and the extra sleeve, vs. $251.92 + tax (and I think free shipping) Edited October 24, 2022 by Pullstart 1 Share this post Link to post Share on other sites
Pullstart 71,267 #270 Posted October 25, 2022 I decided some gussets in the loader arms sound be useful. With a 2” gap, they could be used to tuck the hydraulic hoses into the corners as well! I grabbed some triangles, welded them together, then cut another triangle off ‘em. Added drainage I’ll soften the edges on the belt sander, then burn ‘em in. 1 Share this post Link to post Share on other sites
Pullstart 71,267 #271 Posted October 25, 2022 All better! 2 2 Share this post Link to post Share on other sites
Pullstart 71,267 #272 Posted October 25, 2022 I’m not sure about my bucket travel.. 1 1 Share this post Link to post Share on other sites
Blasterdad 3,168 #273 Posted October 25, 2022 Looking great! You could make another hole for the cylinder pins a couple of inches down on the bucket, it would give you the extra travel both ways you're not sure about. ( pretty sure you already know that ) 2 Share this post Link to post Share on other sites
Pullstart 71,267 #274 Posted October 25, 2022 2 hours ago, Blasterdad said: Looking great! You could make another hole for the cylinder pins a couple of inches down on the bucket, it would give you the extra travel both ways you're not sure about. ( pretty sure you already know that ) I was just making dinner and playing with cylinder positions YES, at the same time! 1 Share this post Link to post Share on other sites
Pullstart 71,267 #275 Posted October 25, 2022 I’m sure some may think or say I post too much, or too many images, or whatnot. I’ve thought about becoming a lifetime member but chose to renew my membership every 2 years to help with the server costs with that said, I’m glad to have found this earlier, to remind myself how the pump mounted. I’m sure I could have figured it out…. this was just easier. 1 Share this post Link to post Share on other sites
