Porangi
227-5 Transmission Belt Size
Porangi
Hi all,
Just a little bit of information regarding replacement drive belts for the 227-5 in the UK if you are not buying OEM that might help someone in the future.
The part number listed is 108427, which specs out as:
  • Top width: 13mm
  • Depth: 8mm
  • Outside Length: 2235mm = 87.99"
Sadly, a number of the first sites I found didn't specify that the 88" is the outside measurement so I having trusted their information and with the old belt still installed I just ordered A88s.
Anyway, as I'm sure you all know, belts are sold based on the internal measurement therefore you would require A86!
Actually now having spent some more time digging for information about the belt I have found sites specifying 88 as the outer diameter. including http://outdoorpowerinfo.com/, which seems like a pretty handy website.
Regards
Chris
gwest_ca
Belts can be very confusing.
If you need a B width belt that is 5/8" wide the industrial belts add 3" to the length.
A B85 would be 88" around the outside.
Garry
  • Similar Content
    • rustyedge1
      By rustyedge1
      Belt in photo is K Force brand A 102742 which is what my local parts place is pushing at 30 bucks plus.
      This one was bought two seasons ago counting this mowing season and it’s not going to make it looks like..
      Any info on better made belts appreciated..
    • River Rat
      By River Rat
      I am looking for the Wheel Horse part number for the Mule Drive belt on my 1984 C145A 11-14KE01. I believe it is 102742. The old one is stretched quite a bit and not sure the outside length. possibly 1/2 by 103 in? 48 inch mower.
      Any help is appreciated!
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • rustyedge1
      By rustyedge1
      Info needed.
      Going to put a oil drain on this engine next oil change and don't really know what I need to start. Trying to get parts ready before time.
      I don't know what size the existing plug is ( see photo ) 3/8" 1/4" ? Getting tired of taking the deck down every time I change oil. Any input welcome.
      Thanks in advance...
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
