96WS6TA 37 #1 Posted March 24, 2017 Got a nice low mileage 97 520h from Craigslist. Guy said it had a lil miss. Shoot at idle a bit then throttle up and it ran fine so I bought it. Got it home and tore into it a little to adjust the valves and saw they were full of gas and junk! So figured I'll pull the motor and saw the other piston wasn't turning with the crank!!!! Well live and learn I guess 2 Share this post Link to post Share on other sites
953 nut 64,188 #2 Posted March 24, 2017 Sure sorry you didn't come here first, lots of great people with a bunch of knowledge and advice. 2 Share this post Link to post Share on other sites
Digger 66 3,525 #3 Posted March 24, 2017 This is a great opportunity for a transplant / re-power ! Think positive ! 2 Share this post Link to post Share on other sites
WHX?? 55,113 #4 Posted March 24, 2017 (edited) Ouch sorry to hear this....No chance of cleaning it up & a new piston & rod?? Edited March 24, 2017 by WHX9 2 Share this post Link to post Share on other sites
Sparky-(Admin) 24,646 #5 Posted March 24, 2017 Drop a single Kohler in it...14hp or better and never look back! Mike........ 7 Share this post Link to post Share on other sites
SylvanLakeWH 30,611 #6 Posted March 24, 2017 Yikes! Too bad... 2 Share this post Link to post Share on other sites
Jerry77 1,218 #7 Posted March 24, 2017 6 minutes ago, Sparky said: Drop a single Kohler in it...14hp or better and never look back Good advice - and don't forget to change the pulley for using it in your hydro....like Digger said: think positive... 2 Share this post Link to post Share on other sites
96WS6TA 37 #8 Posted March 24, 2017 (edited) I have a 16 horse onan??? But It just mentally won't be the same ha 56 minutes ago, WHX9 said: Ouch sorry to hear this....No chance of cleaning it up & a new piston & rod?? The Cyclinder is pretty scored up Edited March 24, 2017 by 96WS6TA 2 Share this post Link to post Share on other sites
ericj 1,579 #9 Posted March 24, 2017 if you already have a extra 16 hp onan, stick it in and run it for now, and then when you find another motor swap it back to a 20, I'm actually looking to put a 16 in a 520 chassis to use as a mower tractor. then I get the swept front axle and the as I feel slightly better eaton 1100 520 trans. not sure it's any better then any other eaton 1100, but from what I've seen personally my 520-H pushes snow better then some of the 416-H I've used . You also get save a LITTLE amount of fuel over the 20 hp motor. So yea I have no problem with a 516-H. Although I have enough 520 to play with that I really won't miss the extra 4 hp. eric j 2 Share this post Link to post Share on other sites
96WS6TA 37 #10 Posted March 25, 2017 Ya it should bolt right up correct? Wiring and all? 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #11 Posted March 25, 2017 Should be 100% plug in play if it's a 16 hp Onan, Jeff. 2 Share this post Link to post Share on other sites
Ed Kennell 44,959 #12 Posted March 25, 2017 Sorry you got a burnt with the 520 lemon @96WS6TA, let's make some 510 lemonade. Has anyone ever made a one lunger out of one of these half dead P220s? What would be involved? Remove the rod, piston, and valves on the dead cylinder. Block off the intake and exhaust. Balance? Fuel adjustment? 2 Share this post Link to post Share on other sites
ericj 1,579 #13 Posted March 25, 2017 2 minutes ago, Ed Kennell said: Sorry you got a burnt with the 520 lemon @96WS6TA, let's make some 510 lemonade. Has anyone ever made a one lunger out of one of these half dead P220s? What would be involved? Remove the rod, piston, and valves on the dead cylinder. Block off the intake and exhaust. Balance? Fuel adjustment? leave the old piston in, help stop anything from getting to the crankcase. pull the valves and put a plate over the intake, don't know how it would work but, I've seen tractors running on one cylinder and the owner never new it lost a cylinder till I pointed it out. and they didn't run half bad. maybe in my spare time lol I could take one of my blown motors that I picked up for parts and try it eric j 3 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #14 Posted March 25, 2017 I had a similar situation. Bought 416 with onan not running right. Ended up parting and the guy that was buying the motor wanted to pull the head and we found there was no piston on one side. I ended up gvingi him the motor 3 Share this post Link to post Share on other sites
HorseFixer 2,014 #15 Posted March 25, 2017 Now wait just a cotton picken minute here! I have not seen a photo shoot of the tractor yet! Sides Front Rear all around. How much did you pay for it? How many Hours on the tractor? I wouldn't be cobbling up a perfectly good tractor with a Kohler. I love my Kohler's too don't get me wrong but why take the easy way out doesn't anyone do anything right anymore? Look inside a Kohler plastic oil pump gears stamped Aluminum Onan Cast Iron Oil Pump Steel Gears. You get what you pay for. ~Duke 5 Share this post Link to post Share on other sites
ericj 1,579 #16 Posted March 25, 2017 I'll take all of the free onan's that anybody wants to give me. FREE is good 8 minutes ago, stevebo said: I had a similar situation. Bought 416 with onan not running right. Ended up parting and the guy that was buying the motor wanted to pull the head and we found there was no piston on one side. I ended up gvingi him the motor eric j 3 Share this post Link to post Share on other sites
Ed Kennell 44,959 #17 Posted March 25, 2017 Go for it Eric. Give me a call when you're ready to fire it up. Might be the baddest 10HP engine around. And the heaviest. 3 Share this post Link to post Share on other sites
N3PUY 1,031 #18 Posted March 25, 2017 I bought one that ran...... but poorly. I sold parts off the Onan and made my money back. So I got a tractor without motor for free! And a deck! 2 Share this post Link to post Share on other sites
HorseFixer 2,014 #19 Posted March 25, 2017 (edited) That looks like TERMITES in the cylinder! Edited March 25, 2017 by HorseFixer 1 Share this post Link to post Share on other sites
96WS6TA 37 #20 Posted March 25, 2017 I ran the numbers it a 97 4 Share this post Link to post Share on other sites
HorseFixer 2,014 #21 Posted March 25, 2017 Got any more close up pics? How may Hrs? Share this post Link to post Share on other sites
ericj 1,579 #22 Posted March 25, 2017 (edited) 14 minutes ago, 96WS6TA said: I ran the numbers it a 97 what is the tractor 2 nd from the back against the wall, now that I look at it closer I would guess a 312-A or a 314-A, thought at first it was a lawn tractor vertical shaft tractor, the console didn't look right from the angle in the photo eric j Edited March 25, 2017 by ericj 2 Share this post Link to post Share on other sites
HorseFixer 2,014 #23 Posted March 25, 2017 28 minutes ago, 96WS6TA said: I ran the numbers it a 97 Is the one with bad engine the one against the wall? 1 Share this post Link to post Share on other sites
Wishin4a416 2,473 #24 Posted March 25, 2017 (edited) My guess would be be far left. Or near left by the grille. Edited March 25, 2017 by Wishin4a416 1 Share this post Link to post Share on other sites
96WS6TA 37 #25 Posted March 25, 2017 the bad 520 is next to grill the 416 will be the donor and that's an old 312 against the wall and another 312 with the plow 1 Share this post Link to post Share on other sites
