jerrell 1 #1 Posted January 21, 2009 :thumbs: i was surfing the web a couple of weeks ago , and ran across an ad about a sealer that was stated was 100% garanteed to stop oil seals from leaking, i have a leak on my older tractor and was wonderin if any one had tried any sealers, the ad stated it would stop hydro leaks as well, i have a small leak on the C-175 hycro cyl , it leaks just enought to cause a dust build up and thought i may try it , if i can find the ad again, i remember that there was at least one member on here that dealt with, sold , or worked with oils, lubes, and stuff of that nature but can't remember who or find his post. has anyone ever tired this stuff and if so does it work or hurt the system??? Share this post Link to post Share on other sites
KyBlue 655 #2 Posted January 21, 2009 Well... Brake Fluid will work to swell up the seals in the hydro, cause we used to use it in automatic trannies...BUT its hell on the internals.. Share this post Link to post Share on other sites
Sparky-(Admin) 23,146 #3 Posted January 21, 2009 I think those "fix-it-all-in-a-can" products only buy you some time and just prolong the inevitable. Mike........ Share this post Link to post Share on other sites
Teddy da Bear 11 #4 Posted January 21, 2009 I have a lot of "inevitables" to prolong! :thumbs: Share this post Link to post Share on other sites
jerrell 1 #5 Posted January 22, 2009 :whistle: i agree mike , i was interested because this ad stated it was a new type that did something to the seals and made them ok again, BUT , never seen anything redo a seal so thought i would ask, i wish i could find that darn ad again been searching all PM, said was made for the military, :thumbs: Share this post Link to post Share on other sites
kpinnc 14,628 #6 Posted January 22, 2009 Jerrell, I wouldn't put ANY additives in a hydro for the purpose of stopping leaks. The tolerances are so tiny inside a hydro that you may just lock it up completely. You'd be much better off having the cylinder repaired. A small leak isn't worth destroying a hydro that could cost $1000 to fix. Kevin Share this post Link to post Share on other sites
Nick 13 #7 Posted January 22, 2009 Id be hesitant to add anything in a Wheel Horse auto unless it was already weak and might get replaced. Then again I would let a cylinder leak some fluid and not worry to much if its just wet and not a continuous drip. This product says its compatible with transmission fluids. Im not sure how an additive would blend with engine oil, I assume the C has oil not ATF. http://www.barsproducts.com/T20L.htm :thumbs: Share this post Link to post Share on other sites
jusjeepn 59 #8 Posted January 23, 2009 I agree with Mike! There never has been nor will there ever be a "mechanic-n-a-can". You'll just be prolonging the inevitable. Pat Share this post Link to post Share on other sites
Buzz 502 #9 Posted January 23, 2009 There never has been nor will there ever be a "mechanic-in-a-can". Oh yes there will! Didn't you see Eldons garage addition? It has a bathroom. "Hey where's Eldon?" "I dunno, he might be in the can"......... :thumbs: Share this post Link to post Share on other sites
jusjeepn 59 #10 Posted January 23, 2009 Got me Buzz :whistle: Share this post Link to post Share on other sites
noncritical 5 #11 Posted January 23, 2009 machanic-n-a-can ? is that when he hands you the bill ? :thumbs: Share this post Link to post Share on other sites
