Jeff-C175 7,207 #26 Posted October 9, 2021 5 hours ago, Handy Don said: by TESTING parts before buying new ones Agree! The time spent spending money and throwing parts at the problem would be better spent learning how it works and then logically approaching the problem in a systematic way and troubleshooting to find the problem and THEN throw money at it. At the end of the day you will be ahead of the game. 1 Share this post Link to post Share on other sites
Redline69 27 #27 Posted October 10, 2021 Problem is the engine dies after using it for a while, then the engine gets hot. It might re start once or twice for a short time, but then it's done and has to be parked until it cools off..then it will start and run again. Share this post Link to post Share on other sites
cleat 8,921 #28 Posted October 10, 2021 I have attached a test for the ignition. Do this test with the engine cool and once again right after it dies and see what changes. Troubleshooting the electronic ignition module for P Series.pdf 1 1 1 Share this post Link to post Share on other sites
Redline69 27 #29 Posted October 10, 2021 Thanks Cleat, will do this test and report back. Share this post Link to post Share on other sites
Redline69 27 #30 Posted October 19, 2021 OK, sorry for the big delay getting back here..farming and life gets in the way sometimes.. I've determined from your test Cleat, that I need new ignition module and ...Trigger ring? does that go around the crank shaft? I can't find part numbers on these.. again, assistance would be appreciated. Thanks. Share this post Link to post Share on other sites
lynnmor 8,740 #31 Posted October 20, 2021 52 minutes ago, Redline69 said: OK, sorry for the big delay getting back here..farming and life gets in the way sometimes.. I've determined from your test Cleat, that I need new ignition module and ...Trigger ring? does that go around the crank shaft? I can't find part numbers on these.. again, assistance would be appreciated. Thanks. 166-0785 166-0767 166-0786 Or get the complete set. 1 Share this post Link to post Share on other sites
Redline69 27 #32 Posted October 21, 2021 Thanks lynnmor, I'm going to see if I can source that kit within Ontario first, otherwise I might see if that outfit ship here to Ontario. Share this post Link to post Share on other sites
lynnmor 8,740 #33 Posted October 21, 2021 11 hours ago, Redline69 said: Thanks lynnmor, I'm going to see if I can source that kit within Ontario first, otherwise I might see if that outfit ship here to Ontario. That "kit" is just a group of parts put together by that supplier. Google the part numbers along with Onan and you should be able to find new and used parts. You may only need the module, the gray ring is rather trouble free, the insulator wasn't included on earlier models but they should be used and the old one may be good. The key should be OK for reuse. 2 Share this post Link to post Share on other sites
