953 nut 62,065 #2 Posted January 25, 2017 I have done this on a smaller scale using an empty 15" rim with a chain double wrapped around a small stump, run it over the rim and hook it to the , plucks them right up out of the ground! 3 Share this post Link to post Share on other sites
DougC 2,643 #3 Posted January 25, 2017 If you have the right type of soil I can see how this would work. The last stumps I removed required a tracked skid loader and digging a big hole even with a tall stump as pictured. 1 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #4 Posted January 27, 2017 Just be careful. I've seen farmers lock the differential, throttle up, and then when the chain tightens, rotate the entire tractor around the rear axle and end up with the tractor on top of them. 1 Share this post Link to post Share on other sites
