Brandon hill 4 #1 Posted January 15, 2017 I have a kohler k341 that will not run. I put a new coil, condeser, spark plug, points, fuel line, and carburetor. All it wants to do a blow a flame out of exhaust. Any ideas of what might be my problem Share this post Link to post Share on other sites
JAinVA 4,638 #2 Posted January 15, 2017 (edited) Sounds like a hung up exhaust valve or at least one that is not seating.Pull the breather and see if the valves are moving.If they are ,check valve lash.There is ample info if you use the search function for info to do both. Edited January 15, 2017 by JAinVA 4 Share this post Link to post Share on other sites
Brandon hill 4 #3 Posted January 15, 2017 One of the valves is sitting all the way down, it looks to be the one that the spark plug hits, could that be my problem? 1 Share this post Link to post Share on other sites
JAinVA 4,638 #4 Posted January 15, 2017 (edited) Yup,That's the exhaust valve and its stuck open.Thats the problem.You will need to remove the valve and clean the stem and valve guide.Nothing hard core if you have a valve spring compressor.The cleaning is relatively simple.Light attention with scotchbright or fine grit sand paper.Make sure to use a new head gasket at reassembly.They are not that expensive. Edited January 15, 2017 by JAinVA 4 Share this post Link to post Share on other sites
roadapples 6,985 #5 Posted January 15, 2017 Good luck and Share this post Link to post Share on other sites
Brandon hill 4 #6 Posted January 15, 2017 Man thanks alot i will have that pulled out am to fixer up 1 Share this post Link to post Share on other sites
953 nut 63,106 #7 Posted January 15, 2017 Sounds like Jim got you headed in the right direction. One more thing, after ti is running and has warmed up remember to torque the head bolts again. 3 Share this post Link to post Share on other sites
N3PUY 1,031 #9 Posted January 15, 2017 7 hours ago, Brandon hill said: it looks to be the one that the spark plug hits, If the valve "hits" the spark plug could be that the valve is bent?!?! It looks like it is in the picture. Wrong spark plug? 4 Share this post Link to post Share on other sites
JAinVA 4,638 #10 Posted January 15, 2017 N3PUY has a good eye and a very good point.Check to see if the exhaust valve is bent when you get it out. 3 Share this post Link to post Share on other sites
KC9KAS 4,745 #11 Posted January 15, 2017 @Brandon hill to Share this post Link to post Share on other sites
Tuneup 1,452 #12 Posted January 15, 2017 If you don't have a spring compressor, you can have someone hold down the valve (or turn the engine on its head) and then compress the spring with two screwdrivers or even a pair of pliers used as levers. It's what I do. Putting it back in with this method is more difficult. I put twine on either side of the spring and compress it in a vise - which I do have - and take great care! Tie the twine and then release the vise pressure. Place it in, attach collars and cut the twine. Sweet. Vises have many uses but spring compressors are used once and then put away for X years. Useful tool but a 'unitasker' as the cook once said. Either that, or I'm just a cheap Southern boy. 4 Share this post Link to post Share on other sites
JAinVA 4,638 #13 Posted January 15, 2017 Put in many a u joint with a vise.They can be used for many tasks if you are careful and creative.I got lucky with my valve spring compressor.Can't beat free. 2 Share this post Link to post Share on other sites
Brandon hill 4 #14 Posted January 15, 2017 I shot some carb cleaner on ot and it went down like supposed to but still no fire i know for face its not hitting the new plug that may have been because the owner had another plug in there that was way to long and wasnt screwed in all the way sonit wouldn't hit the valve Share this post Link to post Share on other sites
JAinVA 4,638 #15 Posted January 15, 2017 Just so I understand.Exhaust valve is no longer stuck.Thats good.It was shooting fire out of the exhaust before no fire at all now.Is that right? 1 Share this post Link to post Share on other sites
Brandon hill 4 #16 Posted January 15, 2017 1 hour ago, Tuneup said: If you don't have a spring compressor, you can have someone hold down the valve (or turn the engine on its head) and then compress the spring with two screwdrivers or even a pair of pliers used as levers. It's what I do. Putting it back in with this method is more difficult. I put twine on either side of the spring and compress it in a vise - which I do have - and take great care! Tie the twine and then release the vise pressure. Place it in, attach collars and cut the twine. Sweet. Vises have many uses but spring compressors are used once and then put away for X years. Useful tool but a 'unitasker' as the cook once said. Either that, or I'm just a cheap Southern boy. I feel you on the cheap and southern part lol im from west Te 6 minutes ago, JAinVA said: Just so I understand.Exhaust valve is no longer stuck.Thats good.It was shooting fire out of the exhaust before no fire at all now.Is that right? Yes it was , now i cant get it to spark off the points 1 Share this post Link to post Share on other sites
JAinVA 4,638 #17 Posted January 15, 2017 Okay.I guess I don't need to tell you to recheck all the electrical connections.If coil,plug and points are new it has to be something simple. 1 Share this post Link to post Share on other sites
JAinVA 4,638 #18 Posted January 16, 2017 (edited) It ain't about cheap as much as making do with what ya got.Not a Dam@ thing wrong with that.A country boy can survive.JAinVA Edited January 16, 2017 by JAinVA 3 Share this post Link to post Share on other sites
Brandon hill 4 #19 Posted January 16, 2017 aftet getting exhaust vale to seat i came to the conclusion to replace the one thing i did not, the condensor Share this post Link to post Share on other sites
Brandon hill 4 #20 Posted January 19, 2017 ok fellas i got it running and rode it around awhile then it started sputtering and quit well now i cant get the point to spark but it's getting power to them, i hooked a teat light to the pos side of battery and the other to the point and when I turned the motor over the light came on Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,853 #21 Posted January 19, 2017 7 hours ago, Brandon hill said: ok fellas i got it running and rode it around awhile then it started sputtering and quit well now i cant get the point to spark but it's getting power to them, i hooked a teat light to the pos side of battery and the other to the point and when I turned the motor over the light came on Check the points this way. Ground the test light on any chassis metal or battery (-). Turn the motor over and watch for constant power at the coil (+). Now move to the coil (-) and turn it over. When the points are open you should have power. When the points are closed you should have 0 power. If you don't get 0 power the contacts are likely dirty and not making electrical contact. Clean up the point's contact surfaces. The light should flash once for every 2 turns of the crankshaft because the camshaft turns 1/2 the speed of the crankshaft. Garry 3 Share this post Link to post Share on other sites
953 nut 63,106 #22 Posted January 19, 2017 (edited) You may want to go back and adjust the points, they also set the timing. Use the attached method to set the points. Kohler static_timing.pdf Edited January 19, 2017 by 953 nut 2 Share this post Link to post Share on other sites
JAinVA 4,638 #23 Posted January 19, 2017 Richard, That was really informative.For some reason I have a low hour K341 that won't run worth beans at .020 I have the points set at .028 and it starts and runs fine.When the weather warms up I will use that method and see what I get. 1 Share this post Link to post Share on other sites
Brandon hill 4 #24 Posted January 20, 2017 On 1/19/2017 at 3:30 AM, gwest_ca said: Check the points this way. Ground the test light on any chassis metal or battery (-). Turn the motor over and watch for constant power at the coil (+). Now move to the coil (-) and turn it over. When the points are open you should have power. When the points are closed you should have 0 power. If you don't get 0 power the contacts are likely dirty and not making electrical contact. Clean up the point's contact surfaces. The light should flash once for every 2 turns of the crankshaft because the camshaft turns 1/2 the speed of the crankshaft. Garry When i move it to the coil side (-) do i put the other on (+) or leave it at the (-)? Share this post Link to post Share on other sites
953 nut 63,106 #25 Posted January 20, 2017 The wire going to the battery ground ( - ) stays there. Share this post Link to post Share on other sites
