HeyMrP
Newbie here and just got a 310-8
JERSEYHAWG /  Glenn
:text-welcomeconfetti:       :wh:         :text-welcomeconfetti:
Nice first wheel horse, best of luck.
Glenn
JC 1965
:WRS:
jackhammer
Good looking tractor you have there...Welcome
ClassicTractorProfessor
:text-welcomeconfetti: Nice looking first Wheel Horse you have there. I started out partial to the older models but have recently began looking for for a newer tractor like yours. Beware though as like others have said these little guys do like to multiply. Good luck with your new Horse
JAinVA
One thing for sure if they don't multiply they ain't Wheel Horses.
Edited by JAinVA
HeyMrP
Everyone keeps warning me that these things multiply. Should I be worried?
  • Like 6
SylvanLakeWH
Yes...
  • Like 4
No reason to worry, unless you're like me and running out of room LOL
  • Like 3
JAinVA
It is funny until you have a yard full of them,but you get the point.
Edited by JAinVA
Ed Kennell
There is no known  vaccine  to prevent it and no known cure. The dreaded WHA is spreading uncontrollable.
  • Like 3
JAinVA
AMEN!
I wished I had taken keyboarding in high school it would have saved all the edits.
HeyMR P,
Bet you didn't see these responses coming.Welcome to Red Square
Edited by JAinVA
Tonyp
congrats ! great find, great machine. I bought our  310-8  new in 1987, over 1900 hours still runs  strong.
Edited by Tonyp
TDF5G
:WRS: That's a mighty fine lookin' Horse you have there!
Edited by TDF5G
HeyMrP
Thanks for the warm welcome everyone. Already found a lift spring (ordered) and rerouted my blower belt correctly thanks to your help. I'll be using, tinkering, and beautifying her and will be sure to keep ya'll updated!
jay bee
:text-welcomeconfetti: to :rs:MrP.  I know I'm late on this subject but be sure to put your lift rod stud in the TOP hole of the tractor's lift arm.  It makes the blower raise much easier than if in the hole below.  Don't ask me how I found that out!!!  Over and over!!!
By the way, where in Michigan are you located?  I'm in Kalamazoo.
Jim
HeyMrP
Jim
I'm in Kimball. I only see one hole for the spring to go in. I'm about to go install it. Will take a pic and post for folks to confirm I got it right! That will be in a thread I started in the implements forum.
Edited by HeyMrP
wrightorchid
The only thing that stops me from many tractors is money, and the many other hobbies I am involved with.  Welcome to Red Square, become a supporter ( in the store section at the top of the page) and you will be able to add many pictures.  This is a great group, and amazing knowledge.
jay bee
I was not referring to the spring.  I was talking about the lift rod stud (sometimes referred to as the flag) and the hole you put it in on the lift arm.
Kimball....you're almost in Canada, but then most of us Michiganders are also!
Jim
HeyMrP
Jim
Canada, eh? Ya, dem guys are just over da river dare.
  • Similar Content
    • Fordiesel69
      By Fordiesel69
      Looking for the OEM nelson muffler that fits the Kohler Magnum M10 thru M16 engines found on the following tractor list:
      310-8
      310-H
      312-8
      312-H
      314-8
      314-H
      410-8
      410-H
      412-H
      412-8
      414-8
      414-H
      416-8
      416-H
      and also and "A" models that had the kohler magnum.
      I dropped mine off to be welded and it came up missing.  It was not good to begin with so im sure they accidentally tossed it out with the way it looked.
    • OHLB
      By OHLB
      Newbie here. 310-8 won't start. Battery is dated 10/19. Did crank a couple times but started losing ummph. Should I replace it or attempt to charge it? Can't tell if the battery is frozen. Never knew until today that batteries could freeze and that it's dangerous to charge a frozen battery. It's been single digits with wind chill the last couple weeks here.
    • Big Rig
      By Big Rig
      ISO clutch neutral safety switch for 310-8
      or alternative
    • Rob R
      By Rob R
      Soo couple of years back did a pulley change on the tranny from 6 inch to 4.5 and used a 1/2 X 79 belt to make it work and it worked fairly well but wanted to get back to a 5/8 drive belt so went to a 5/8 x 81 inch belt and added a second flat Idler pulley. I simply cannot believe how smooth and sharp it shifts and drives now!  The added flat Idler was 2 3/4" with a 5/8ths bore used and existing hole on the side shroud and just opened it up a bit. I use to slip a bit on steep hill with the 79" slips no more, the belt drives and the clutch is  LOT smoother and in the right pedal area.... Will see how it holds up cut 3/4 of an acre of grass yesterday NO issues.
    • Ifixoldjunk
      By Ifixoldjunk
      So I was out mowing the other day with my 310-8 and somehow snagged my wheel in a hole in the yard. Anyways I pretty much destroyed my ball joints. I've since replaced the tie rod with junkyard parts but I was wondering if anyone's found a heavy duty aftermarket replacement for the tie rod assembly.
      Like would generic adjustable go-kart tie rods do the trick?
