Countdown To Christmas!
ti-jean
44'' snowthrower chain block tensioner
ti-jean
 Hi all after a few job now my auger drive chain  is gone after each blowing I have to tight the chain  this wood block make me crasy loll now i was thinking to replace  by  bearing sprocket
any of you guys try-it if so let see a pics of the sprocket dimension and how did you install it on the holding bracket . the end :)
instead of that I wish you a health and snow  :greetings-clappingyellow:
WVHillbilly520H
The new one available from TORO is now "nylon" vs wood and if you search there is post or two with the idler(dirt bike)sprocket upgrade ,Jeff.
Kurt-NEPA
This is what I did
Kurt-NEPA
This was the original tensioner
Another Photo
ti-jean
37 minutes ago, Kurt-NEPA said:
This is what I did
Nice idea :handgestures-thumbupright:  did you need to make your chain longer to fit this bearing chain sprocket if so if you rember what chain length did you install
 thank's jean
Kurt-NEPA
Yes, I did need a longer chain.  I didn't record the length.  I just moved the adjustment to the shortest point, wrapped the new chain around it, then cut the chain at the next longest link.  No rocket science here.  BTW, I got the new chain from TSC.
ti-jean
22 hours ago, Kurt-NEPA said:
This is what I did
 thank's jean
Houra Houra thank's to all of you guys you make my day i did same as the pics of Kurt-NEPA and the other I also change the impeller  block bearing ,chain , but one thing i didn't know to change the impeller bearing I did'n have to remove all the front Jesus  crisis :bitch:the problem was with the cross bar  anyway everything is done that is the point i will come later with a pics . It cost me the idler and solder bolt 1/2''x 2'' chain impeller block bearing 50.00$ canadian money
thank again :handgestures-thumbupright:
Edited by ti-jean
ad some more thing
Kurt-NEPA
Got er Done!!!  Congrats.  :handgestures-thumbupright:
