ti-jean 45 #1 Posted January 12, 2017 Hi all after a few job now my auger drive chain is gone after each blowing I have to tight the chain this wood block make me crasy loll now i was thinking to replace by bearing sprocket any of you guys try-it if so let see a pics of the sprocket dimension and how did you install it on the holding bracket . the end instead of that I wish you a health and snow Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #2 Posted January 12, 2017 The new one available from TORO is now "nylon" vs wood and if you search there is post or two with the idler(dirt bike)sprocket upgrade ,Jeff. 1 Share this post Link to post Share on other sites
Kurt-NEPA 755 #3 Posted January 12, 2017 This is what I did 3 Share this post Link to post Share on other sites
Kurt-NEPA 755 #4 Posted January 12, 2017 This was the original tensioner Another Photo 2 Share this post Link to post Share on other sites
ti-jean 45 #5 Posted January 12, 2017 37 minutes ago, Kurt-NEPA said: This is what I did Nice idea did you need to make your chain longer to fit this bearing chain sprocket if so if you rember what chain length did you install thank's jean Share this post Link to post Share on other sites
Kurt-NEPA 755 #6 Posted January 12, 2017 Yes, I did need a longer chain. I didn't record the length. I just moved the adjustment to the shortest point, wrapped the new chain around it, then cut the chain at the next longest link. No rocket science here. BTW, I got the new chain from TSC. 1 Share this post Link to post Share on other sites
ti-jean 45 #7 Posted January 12, 2017 (edited) 22 hours ago, Kurt-NEPA said: This is what I did Nice idea did you need to make your chain longer to fit this bearing chain sprocket if so if you rember what chain length did you install thank's jean Houra Houra thank's to all of you guys you make my day i did same as the pics of Kurt-NEPA and the other I also change the impeller block bearing ,chain , but one thing i didn't know to change the impeller bearing I did'n have to remove all the front Jesus crisis the problem was with the cross bar anyway everything is done that is the point i will come later with a pics . It cost me the idler and solder bolt 1/2''x 2'' chain impeller block bearing 50.00$ canadian money thank again Edited January 12, 2017 by ti-jean ad some more thing 2 Share this post Link to post Share on other sites
Kurt-NEPA 755 #8 Posted January 13, 2017 Got er Done!!! Congrats. 1 Share this post Link to post Share on other sites
