Razkid 69 #1 Posted December 29, 2016 This was dropped off to me by the 520-H's previous owners friend. I asked him to go through the shed and garage to see if there were any other things painted red that might go with the tractor. It's about 4' long and heavy. Is this something Wheel Horse? He also found the missing pulley cover that goes on the mower deck and one tiller blade. Never hurts to ask! 3 Share this post Link to post Share on other sites
rjg854 12,850 #2 Posted December 29, 2016 It's the bar that raises a snowthrower 7 Share this post Link to post Share on other sites
roadapples 6,987 #3 Posted December 29, 2016 5 minutes ago, Ranger13148 said: It's the bar that raises a snowthrower Yup, that`s it..... 1 Share this post Link to post Share on other sites
Razkid 69 #4 Posted December 29, 2016 (edited) Do you mean to manually lift the snowthrower? I don't see anything like it in the 06-44SC01 parts list. Does it go onto some other model of snowthrower? Edited December 29, 2016 by Razkid 1 Share this post Link to post Share on other sites
roadapples 6,987 #5 Posted December 29, 2016 Yes.. 1 Share this post Link to post Share on other sites
GlenPettit 1,718 #6 Posted December 29, 2016 (edited) Yes (and no), there's a big mechanical advantage ––– you're using the large lever on the left plus a strong 'helper spring' (and a 'flag') underneath, so just your left arm while sitting can raise the snowblower easily. Ask him to keep searching and keep a big eye open –– it's those little small parts that are often left behind that have become so valuable and hard to find, and even harder to reproduce, like the small 'flag' and 'Spring', etc. Edited December 29, 2016 by GlenPettit 4 Share this post Link to post Share on other sites
roadapples 6,987 #7 Posted December 29, 2016 Can`t see it in that picture, it`s underneath the tractor.. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #8 Posted December 29, 2016 NO , not for the 2stage but for a single stage, as you can tell there's a cradle/frame and scissors type lift linkage with a smaller lift arm on the 2stage, on the single it's frame latches into the front attac-a-matic then that big pole attaches to the bottom of the auger housing/frame then under the tractor to the rock shaft,Jeff. 6 Share this post Link to post Share on other sites
Razkid 69 #9 Posted December 29, 2016 Thanks to all for the replies and to Jeff for clarifying it to me! I'll have to ask if another tractor that the previous owner owned had a single stage on it. It might go on the tractor that the person who brought it to me now owns! 5 Share this post Link to post Share on other sites
857 horse 2,588 #10 Posted December 29, 2016 Just an off topic question,,,,,,,,What is all the concrete for in the floor.??? Share this post Link to post Share on other sites
Razkid 69 #11 Posted December 30, 2016 In the process of breaking up the concrete floor in the barn. Share this post Link to post Share on other sites
6wheeler 675 #12 Posted December 30, 2016 Still off topic. Hammerdrilling to start the cracks? Back on topic. Do those snow blowers manually lift pretty easy? Haven't had a snowblower on the place since the Bobcat showed up. Never had a tractor one. Just a walk behind butt kicker. Share this post Link to post Share on other sites
Razkid 69 #13 Posted December 30, 2016 Yes to hammerdrilling! Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #14 Posted December 30, 2016 15 hours ago, 6wheeler said: Still off topic. Hammerdrilling to start the cracks? Back on topic. Do those snow blowers manually lift pretty easy? Haven't had a snowblower on the place since the Bobcat showed up. Never had a tractor one. Just a walk behind butt kicker. With the lift assist spring they lift ok but all mine are hydro so I'm just going by other comments on ,as for the Bobcat I hope yours is new enough with "floating" loader as my BIL/FIL's doesn't and tears up more sod than clearing snow and takes FIL twice if not longer to move the snow than me sitting in a "warm" cab blowing it over the house and melting away long before his iceberg piles, not knocking the Bobcat, but I do know when the DOT can't push the snow back past the guard rails on the mountain highway going back to my home in WV they bring out the 8' tall 12' wide truck mounted snow blower to keep both lanes open for travel,Jeff. 5 Share this post Link to post Share on other sites
ohiofarmer 3,383 #15 Posted December 31, 2016 Just a suggestion on tearing out that floor. If you can get some forklift forks on a skidsteer attachment or even just hook an edge with a backhoe. Lift a piece of slab up almost vertical and then drop it and it probably will break up when it hits the ground. For tougher pieces, we would throw lumps of concrete under them to create a high spot and then WHAM-- break them up. The larger pieces you can lift and carry out with a forklift attachment, the better. As a bonus, the earth beneath the slab is pretty much undisturbed. If I were doing the job, we would take the slab pieces outside and stack maybe three of them on a dump truck, Then push them forward with the forks and repeat as necessary. Saves so much time that you would not believe it. Of course, I cannot see the room you have vertically above that floor, so my technique may not work so well.You do have to be careful around stem walls. Tearing out sidewalks using this method is so fun that you should pay the customer to do it. Good luck with your project. 1 Share this post Link to post Share on other sites
Razkid 69 #16 Posted January 2, 2017 Thanks for the tip Ohiofarmer. It's not my place but I'll pass the tip on to the owner. Share this post Link to post Share on other sites
