obone 142 #1 Posted December 25, 2016 I just got a blade from a member here and wanted to ask tips and video of how you use it to clear snow. Mainly close to the house without going through the garage door. Which way do you push\pull near the house? Thanks. Share this post Link to post Share on other sites
SylvanLakeWH 31,051 #2 Posted December 25, 2016 I go up to the door, drop the blade and then back blade far enough away so I can get behind it and push it out and down the driveway. I'm a big fan of the down the middle - back and forth - without changing the blade direction. Pushes the snow 50% to each side. Work from the middle out... 7 Share this post Link to post Share on other sites
Lane Ranger 11,935 #3 Posted December 25, 2016 (edited) Right up the sidewalk and left and right in front of the garage door ! I keep my door open when plowing just in case the operator hits a foul ball ! I ususally use my B-80 but this was a couple winters ago with my brotehrs 633 and a 1962 snowplow. Here is a You Tube posted video from 2014 using this tractor and plow: Edited December 25, 2016 by Lane Ranger 7 Share this post Link to post Share on other sites
slammer302 2,157 #4 Posted December 25, 2016 I agree with what SylvanLakeWH said. If you have lots of snow make sure you push your piles back as far as you can so you have plenty of room if you get more snow before it has a chance to melt. I also am a fan of the solid lift link. I like to be able to feel the blades movement. I'm not sure what model WH your using but I've had pretty good luck using a commando 8 with wheel weights & 42'' blade. This year stepped it up with a C-160 cab weights & chains. 5 Share this post Link to post Share on other sites
82Caddy 851 #5 Posted December 25, 2016 I shovel a bit (3-4 feet) away from the doors and tight spaces. Just makes it easier. 1 Share this post Link to post Share on other sites
briankd 833 #6 Posted December 25, 2016 1 hour ago, SylvanLakeWH said: I'm a big fan of the down the middle - back and forth - without changing the blade direction. Pushes the snow 50% to each side. Work from the middle out... yes that's the best way i found also been doing that for years and also never used wheel weights been plowing snow with an 857 tire chains only gravel drive never had no issues got wheel weights 2 year ago but never had enough snow since to try them out 1 Share this post Link to post Share on other sites
obone 142 #7 Posted December 25, 2016 OK I understand if I'm coming from the garage, but what if it's a neighbor's house? Do I clear the front or drive up to the garage pull that back some then turn around and finish the push? 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,567 #8 Posted December 25, 2016 Trial and error will be your best teacher, making mistakes makes you learn. Trust me, I made plenty. Good luck. Be carefull. Think things out. Glenn 2 Share this post Link to post Share on other sites
SylvanLakeWH 31,051 #9 Posted December 25, 2016 7 hours ago, obone said: OK I understand if I'm coming from the garage, but what if it's a neighbor's house? Do I clear the front or drive up to the garage pull that back some then turn around and finish the push? In that case, which my son does for his plow jobs, he goes up the drive along the non-house side as far as possible, pushing to the side. Then back blade the garage door area, which is usually closed, then proceed as I explained before - down the middle and working outwards. You want to get as much as possible down and away from the house in case you get a lot of snow over the year. Only want to move it once. Merry Christmas! 1 Share this post Link to post Share on other sites
Tankman 3,528 #10 Posted December 25, 2016 Pushing the white cold nasty stuff from the middle out. I usually push out further than needed at the moment. Need room just in case more nasty junque comes my way. 5 Share this post Link to post Share on other sites
shallowwatersailor 3,221 #11 Posted December 28, 2016 On 12/24/2016 at 11:11 PM, obone said: OK I understand if I'm coming from the garage, but what if it's a neighbor's house? Do I clear the front or drive up to the garage pull that back some then turn around and finish the push? I do five neighbors besides my own driveway. Using the tractor with the blade, I get as close to the garage door without pushing snow against it. I do this as often as I need to until I can then backblade the snow by the door. The tractor that has the snowthrower is equipped with an electric sleeve hitch that has a drag blade on it. I use the snowthrower as close as I can and then turn around to drag the snow out. Then I clean up with the snowthrower again. Share this post Link to post Share on other sites
