T-Mo-(Moderator) 4,889 #1 Posted December 15, 2016 For those who are looking for material for their snow blades and have concrete or asphalt drives, here is a company that makes them. They can be blank or pre-drilled. A guy on WFM used these on his John Deere garden tractor. http://www.fallline.com/snow-removal/snowplow-cutting-edges/ http://www.wfmachines.com/forums/showthread.php/53377-Poly-blade-and-blower-skids-and-blades-mod If I have to remove the snow at our church, which has a paved parking lot, I might buy one for my JD GX345. 5 Share this post Link to post Share on other sites
Tankman 3,528 #2 Posted December 15, 2016 Picked up a free Craftsman blade. Previous owner made his own edge. I don't have any use for the blade but, free it's me. Sitting with no need or use. 2 Share this post Link to post Share on other sites
WHX?? 57,382 #3 Posted December 15, 2016 Wonder if they have a thinner version that one could sandwich across the bottom of the wear blade/scraper on a blower? Cut pieces for the bottom of the shoes 2 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,889 #4 Posted December 15, 2016 2 minutes ago, WHX9 said: Wonder if they have a thinner version that one could sandwich across the bottom of the wear blade/scraper on a blower? Cut pieces for the bottom of the shoes They do custom edges also. http://www.fallline.com/snow-removal/snowplow-cutting-edges/products/custom-cutting-edges/ 1 Share this post Link to post Share on other sites
WHX?? 57,382 #5 Posted December 15, 2016 I see that now Terry ---interesting site... Thanks! 1 Share this post Link to post Share on other sites
varosd 1,185 #6 Posted December 15, 2016 how about these for the snow thrower skids? http://www.sepw.com/snow-blowers/accessories/skid-shoes/ my thrower doesn't have replaceable scraper on bottom I this what I have used on my snow blade https://www.mcmaster.com/#standard-plastic-sheets/=15hfchu 3 Share this post Link to post Share on other sites
shallowwatersailor 3,221 #7 Posted December 15, 2016 This what I bought two years ago. I bought two but the original is still going strong. http://www.ebay.com/itm/UHMW-Polyethylene-Plastic-Sheet-BLACK-1-2-x-4-x-48-/172402724762?hash=item282400cf9a:g:eWkAAOxyiklTkcM8 3 Share this post Link to post Share on other sites
Fun Engineer 863 #8 Posted December 15, 2016 (edited) 1 hour ago, varosd said: how about these for the snow thrower skids? http://www.sepw.com/snow-blowers/accessories/skid-shoes/ my thrower doesn't have replaceable scraper on bottom I use the Robalon skid shoes on my green machines snowblower Don. They are a big improvement over the skinny metal skids. On my Wheel Horse thrower I attached sections of a used poly cutting board to the bottoms of the skids. Edited December 15, 2016 by Fun Engineer Share this post Link to post Share on other sites
KC9KAS 4,746 #9 Posted December 15, 2016 20 minutes ago, shallowwatersailor said: This what I bought two years ago. I bought two but the original is still going strong. And it comes from South Bend IN, so we know it will last! Share this post Link to post Share on other sites
GlenPettit 1,719 #10 Posted December 16, 2016 (edited) After last year and four-time already this year (3 hours each time), only minor wear (5%) on the one edge of this nylon blade ($20): (I'm sold on this for an asphalt drive, quite, very easy to drill, very little wear –– have not used on gravel directly, edge was run high). (at this rate, the two edges may last 10 years: in the pix you see a 20# lead bar temporally hanging on the mule mount, both the front and rear tires have Rim-Guard fluid inside, the weight and tri-rib tires greatly help control steering, blade has 2 upright corner markers, Silicone on blade face). Edited December 16, 2016 by GlenPettit 4 Share this post Link to post Share on other sites
