rickeyg52@hotmail.com 3 #1 Posted December 13, 2016 (edited) oil light blinks while running has not blown up yet. any ideas. 1993 520H Edited December 13, 2016 by rickeyg52@hotmail.com Share this post Link to post Share on other sites
wrightorchid 261 #2 Posted December 13, 2016 Keep an eye on your oil level. Sometimes the sensors go bad. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,146 #4 Posted December 13, 2016 This is for the NN10824 oil pressure switch used on some of the Onan engines. 5 Share this post Link to post Share on other sites
Sarge 3,470 #5 Posted December 13, 2016 I don't know how we'd live without your input on the proper manuals for all things WH - thank you so much for all your help . Sarge 7 Share this post Link to post Share on other sites
wrightorchid 261 #6 Posted December 13, 2016 Looks like the switch is NLA. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,146 #7 Posted December 13, 2016 I don't know if it was ever available through Wheel Horse/Toro. It is an Onan part number and many manuals state they are recorded for reference only. They did the same with Kohler engine parts. Perhaps Boomer will respond. Garry Here is an older thread where a replacement switch was needed but appears it only had one terminal. 1 Share this post Link to post Share on other sites
608KEB 812 #8 Posted December 29, 2016 I have a thread on this. They still make it. But it's expensive. Share this post Link to post Share on other sites
cleat 8,926 #9 Posted December 29, 2016 I was thinking of putting an oil pressure guage on a 520 and eliminating one of the existing guages that I rarely use like the vacuum guage. It could be either electric or mechanical (I would likely just go electric). I already have mine all wired so the hour meter is permanently grounded and run whenever the key switch is on (I would never have the key on and engine off). However, if you want to stay all original, keep your eye on the classified sites, a pressure switch may turn up. Share this post Link to post Share on other sites
cleat 8,926 #10 Posted December 29, 2016 I was thinking of putting an oil pressure guage on a 520 and eliminating one of the existing guages that I rarely use like the vacuum guage. It could be either electric or mechanical (I would likely just go electric). I already have mine all wired so the hour meter is permanently grounded and run whenever the key switch is on (I would never have the key on and engine off). However, if you want to stay all original, keep your eye on the classified sites, a pressure switch may turn up. Share this post Link to post Share on other sites
lynnmor 8,740 #11 Posted December 29, 2016 There are all kinds of automotive pressure switches available. Surely one could be used to replace the OEM switch. Would something like this work? Switch Share this post Link to post Share on other sites
608KEB 812 #12 Posted December 29, 2016 That pressure switch closes to make a complete circuit between 2 and 5 lbs. of oil pressure. Share this post Link to post Share on other sites
boomers_influence 106 #13 Posted December 29, 2016 club my 2016 L-835 price sheet shows the 309-0606 at the memphis warehouse for 16.52. most cummins dealers will charge 20% more than that price. thank you. boomer Share this post Link to post Share on other sites
