classicdmax 190 #1 Posted December 12, 2016 i have a 73 no name 16h hydro....reverse is very lethargic, slow to react and not much speed there at all. the tractor does creep sometimes, so i know i will need to adjust for that, will this adjustment have any bearing on reverse speed/power? forward seems to be strong, and have even put the front of tractor up against my foundation and got wheel spin on asphalt without problem fluids have been changed along with filter, and there is the appropriate amount ATF as i just checked the dip stick. i believe i put in 5qts i havent taken the belt guard off, but there seems to be slop in the belt when running, not sure if this is normal? and input? thanks fellas Share this post Link to post Share on other sites
953 nut 64,269 #2 Posted December 12, 2016 Since the problem is only evident in reverse it could be linkage, but I suspect the Acceleration Valve Springs are bad or the valve itself has an internal blockage. @refracman has a source for the springs if you should need them. Take a look at the manual page 49 on, it shows the valves; the one at the front of the tractor is the reverse valve. Sunstrand Hydro (part 4).pdf Share this post Link to post Share on other sites
classicdmax 190 #3 Posted December 18, 2016 Any suggestion on how to inspect said valve for proper function thanks Share this post Link to post Share on other sites
pfrederi 19,940 #4 Posted December 18, 2016 You have to remove it. The manual covers it well. The hole in the valve is,( as the manual says) very tiny. The smallest torch tip cleaner I had was too big. Has to borrow some fine wire from my wifes crafting supply to clean it. Share this post Link to post Share on other sites
classicdmax 190 #5 Posted February 26, 2017 Today i removed the instruction placard along with steel backing plate...operated tractor and reverse seemed much better. I believe the steel backing plate to be the culprit in limiting travel of hydro shift lever. I used a 1/2" dia metal rasp bit in my drill press as a diy mill and elongated the forward and reverse slots as well as widened the corners a bit. Seems much better in reverse now, at least a bit more speed Share this post Link to post Share on other sites
