ti-jean 45 #1 Posted December 9, 2016 Hi yesterday I check for a air leak at the intake manifold with W40 and there is no air leak at that part the way I check it was to warm-up the engine because the surging problem came only wen the engine is at warm temperature now i am wondering if some of you can tel me what else to verify to diagnostic the surging up and down rev problem the mixture gas screw is set 1 1/4 turn out . thank Share this post Link to post Share on other sites
Ed Kennell 46,621 #2 Posted December 9, 2016 Clean the carb. 1 Share this post Link to post Share on other sites
ti-jean 45 #3 Posted December 9, 2016 That is what I was to do any pics or sheet diagram of the carb . my engine is P216G I-10538b tractor serial 3116oE01 model 10134 thanks Share this post Link to post Share on other sites
Ed Kennell 46,621 #4 Posted December 9, 2016 I suggest you do a search for " onan surging" . You will get 70 results to read about the ONAN surging and the repairs required. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,373 #5 Posted December 9, 2016 Your tractor model number is 31-16OE01 and the serial number is 10134. There is a link to the Onan service manual here you can download. Scroll down the page. Here is a service bulletin on governor hunting in case that is your problem Garry 1 Share this post Link to post Share on other sites
scotty 252 #6 Posted December 9, 2016 I have a 416h i could not get to stop surging. I cleaned the carb 5 times very thoroughly and it ended up being the float was bad and the carb was not quite adjusted right. Share this post Link to post Share on other sites
varosd 1,185 #7 Posted December 10, 2016 like all posters have stated. clean carb remove air cleaner remove top of carb. avoid dropping bolts into carb throat..tends to add to the problem remove float, needle jets. again do not drop parts into throat of carb. compressed air can and carb cleaner are your friends. just don't get carb cleaner on paint if after cleaning carb, like 3 times, move onto governor adjustment threads welcome to Onan world 1 Share this post Link to post Share on other sites
ti-jean 45 #8 Posted December 10, 2016 My god thanks to all I will check everything you tell me the carb and all fit so Il let you know what figure of the real problem Thank again instead how is my English spelling ??? 2 Share this post Link to post Share on other sites
Ed Kennell 46,621 #9 Posted December 10, 2016 (edited) Makes cents to me. to the Edited December 10, 2016 by Ed Kennell 1 Share this post Link to post Share on other sites
ti-jean 45 #10 Posted December 12, 2016 Hi today we have snow after replace the intake manifold gasket the engine surge but only at fast idle without load on PTO after get my yard blow so Il check whit w-40 for any manifold air leak and there's no air leak so the surge problem should be whit the cab thank 1 Share this post Link to post Share on other sites
Ed Kennell 46,621 #11 Posted December 12, 2016 On 12/9/2016 at 8:13 PM, ti-jean said: how is my English spelling ??? Much better than my French spelling ..... and about the same as my English spelling. 1 Share this post Link to post Share on other sites
