jellyghost 378 #1 Posted December 8, 2016 I bought a Craftsman jack, and I couldn't get it to work. The jack has a C-shaped piece of metal that is supposed to cup the front wheel arms. Unfortunately, there is a little triangle of metal keeping the cup from moving around the wheel arm as the tractor rises. I dropped the WH a few times while figuring this out! Does anyone have a way to make this jack work? Do you have a different jack suggestion? Share this post Link to post Share on other sites
Ed Kennell 41,922 #2 Posted December 8, 2016 I had the same problem with one of these lifts. They were designed to lift the tractors with the front tubular bumpers. The WH front axles are too wide to securely stay in the small Cs on the lift. I considered welding on larger Cs, but I sold mine and just use my floor jack. 4 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #3 Posted December 8, 2016 57 minutes ago, Ed Kennell said: I had the same problem with one of these lifts. They were designed to lift the tractors with the front tubular bumpers. The WH front axles are too wide to securely stay in the small Cs on the lift. I considered welding on larger Cs, but I sold mine and just use my floor jack. I always use the floor jack to. Glenn 1 Share this post Link to post Share on other sites
daveoman1966 3,839 #4 Posted December 8, 2016 I use a 1-ton chain hoist. Picks the tractor up to almost vertical to remove / sharpen mower blades. Works lots easier and quicker than a floor jack, which I sometimes use as well. 1 Share this post Link to post Share on other sites
Marv 979 #5 Posted December 9, 2016 I use a Harbor Freight motorcycle jack. Marvin Share this post Link to post Share on other sites
jellyghost 378 #6 Posted December 9, 2016 How do you use a simple floor jack? Is it centered under the front wheel system? Share this post Link to post Share on other sites
Sparky-(Admin) 23,147 #7 Posted December 9, 2016 6 hours ago, jellyghost said: How do you use a simple floor jack? Is it centered under the front wheel system? That is correct, you do need to make sure you don't touch the front axle grease zerk or it will be snapped off. Mike......... 1 Share this post Link to post Share on other sites
daveoman1966 3,839 #8 Posted December 9, 2016 2 hours ago, Sparky said: That is correct, you do need to make sure you don't touch the front axle grease zerk or it will be snapped off. Mike......... Whis is why I use the Chain Hoist.... 1 Share this post Link to post Share on other sites
Sarge 3,465 #9 Posted December 9, 2016 On some jacks it's not hard to remove the swivel plate and figure out what size tubing fits tightly - build a spreader bar with either fixed or sliding saddles out of square tubing . I need to make a new one as soon as I either fix this stupid , junk Chinese/Craftsman aluminum jack's cylinder valves or replace it - probably with a Hein-Warner instead if I can find a used US made one - seems now they are built in China and still carry the name - like everything else . Here's a spreader bar for ideas - https://www.amazon.com/Cross-Floor-Adapter-holds-Extends/dp/B002LGLXM0 Sarge 1 Share this post Link to post Share on other sites
Ed Kennell 41,922 #10 Posted December 9, 2016 Regardless of the type of device used to lift, always use jack stands before placing any body parts under a suspended load. When the standard jack stands won't fit or get in the way, I have made pairs of supports of different lengths from 8" PVC pipe that work under the tires or frame. This makes a very stable platform. Just remember to lock the parking brake and/or block the wheels. 1 Share this post Link to post Share on other sites
