Jakeshorsetuff 36 #1 Posted December 7, 2016 HI I have a k181s engine that leaks oil out of the breather and it has a new gasket can anyone suggest any solutions of what to do? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,373 #2 Posted December 7, 2016 No experience with this engine to know if this is a good fix. Hopefully someone has done this and will respond. Garry 2 Share this post Link to post Share on other sites
stevasaurus 23,748 #3 Posted December 7, 2016 Is the weep hole on the bottom...it has to be to work right. Notice the little hole on the bottom side. If that hole is toward the top...it is your problem. 4 Share this post Link to post Share on other sites
Ed Kennell 46,622 #4 Posted December 7, 2016 (edited) Have you taken the breather valve apart, cleaned all parts, and reassembled properly? Garrys link shows this process. Edited December 7, 2016 by Ed Kennell 2 Share this post Link to post Share on other sites
Jakeshorsetuff 36 #5 Posted December 8, 2016 (edited) I took the breather apart and there was a line of oil under the weep hole is this normal? Edited December 9, 2016 by Jakeshorsetuff Share this post Link to post Share on other sites
slammer302 2,157 #6 Posted December 8, 2016 (edited) Low compression can cause oil to come out the breather. You can add better filter inside to help keep the oil inside the crank case. Edited December 8, 2016 by slammer302 Share this post Link to post Share on other sites
stevasaurus 23,748 #7 Posted December 8, 2016 @slammer302 Where would one get that better filter?? Share this post Link to post Share on other sites
slammer302 2,157 #8 Posted December 8, 2016 6 hours ago, stevasaurus said: @slammer302 Where would one get that better filter?? I make my own out of scotch bright pads. 1 Share this post Link to post Share on other sites
slammer302 2,157 #9 Posted December 8, 2016 The 3M brand 1 Share this post Link to post Share on other sites
Jakeshorsetuff 36 #10 Posted December 9, 2016 Thanks for all your guys help about the breather. 1 Share this post Link to post Share on other sites
Hacksawhero123 351 #11 Posted December 15, 2016 I just went through this with a k161 on my old tiller. Had no problems with oil leakage from the breather until I changed the oil. Everything with the breather assembly was correct. Turns out that I had overfilled it with oil. I discovered this after looking up the oil capacity in the Kohler manual, then draining and measuring how much I had added. My engine does not have a dipstick, just a fill plug. Apparently if you fill to the bottom of the fill plug, its overfilled. I forget the amount of oil the manual calls for, but after measuring that amount and adding it to the crankcase, the leak went away. Good luck. Mark. 3 Share this post Link to post Share on other sites
Hacksawhero123 351 #12 Posted December 15, 2016 Double check this. The Kohler manual says 2.5 pints (1.2 liters) of oil. I suggest draining and measuring how much is in there. It's probably overfilled. If I remember correctly, the full oil level is not above the oil pan gasket. Someone please correct me if I'm wrong. Thanks. Mark. Share this post Link to post Share on other sites
Hacksawhero123 351 #13 Posted December 18, 2016 Jake, any luck on the source of your oil leak? Mark. Share this post Link to post Share on other sites
Jakeshorsetuff 36 #14 Posted January 3, 2017 yes ,the filter was very worn out and it did not retain the oil from the the breather housing. Share this post Link to post Share on other sites
