Dump bucket weight lift capabilities?
By
Bigwatersig, in Implements and Attachments
Similar Content
By 1054 Project
OK, I have my new return spring. As you can see the overall length of the replacement spring is much taller than the old one. I assume I'll need to shorten the spring so that it engages with the outboard holes and at the same time have the "U" sit behind the roll pin. Or am I looking at this all wrong?
Thanks in advance!
By 69-Raider-10
Just brought her home an hour ago! Ran it through the paces and everything checks out! Now shes coming in the shop to get a good tune up, the Bolens plow taken off and replaced, fluids change, some rewiring, a motor cleaning and a couple of new gaskets, and a good carb cleaning. And maybe some fuel lines. 😁 This is my first hydro so its taking some getting used too. LOVE the hydraulic lift though! Dont know how I lasted this long without one!
By frankiefiredog
1975 C-120 Auto. I'm currently working with another RS member on adding a hydraulic lift to my C-120. Other than the valve, cyl, hoses, and couplings, what else might I need to get this switched? Is it pretty much bolt on? Any advice would be great. I appreciate all of your knowledge so much. Thanks.
By hill881
I hooked up an implement lift valve and now the sunstrand 90-4620 hydrostatic does not have enough power to load tractor on to a trailer. If I unhook the valve the hydrostatic has all kinds of power. Is there something that Im missing or do I have the hose hooked into the wrong ports? Does anyone have a diagram on how the hose hook to the hydrostatic and what ports.
By Ed Kennell
My 75 C-160 with a sundstrand 90-1140 hydro was getting weak, so I put in a sundstrand 90-2046 from my 72 charger 12 parts tractor. Everything fit up and it works fine.
My question is can the hydraulic lift cyl be used on the 90-2046, and if so ,where do the two lines connect on the 2046 ??
Thanks for any help.
Ed
