dirtnap 39 #1 Posted November 27, 2016 I've been spending a lot of time reading up here recently and I keep hearing about the "swept axle" some WHs have. Can someone explain exactly what that's all about? Are they swept backwards? Do they have an advantage over "non-swept" axles? What years were they used? Thanks Share this post Link to post Share on other sites
squonk 44,710 #2 Posted November 27, 2016 They were used on 520's to allow you to run a 60" deck. Share this post Link to post Share on other sites
rjg854 12,583 #3 Posted November 27, 2016 yeah you already said that once Share this post Link to post Share on other sites
dirtnap 39 #4 Posted November 27, 2016 Simple enough! thanks! Share this post Link to post Share on other sites
squonk 44,710 #5 Posted November 27, 2016 13 minutes ago, Ranger13148 said: yeah you already said that once The internets have been playing havoc in my neck of the woods. another thing the swept axle does is force you to buy a pricey extension if you want to use a snowplow, 1 Share this post Link to post Share on other sites
KC9KAS 4,744 #6 Posted November 27, 2016 3 hours ago, dirtnap said: Are they swept backwards No, they are swept forward to allow the front wheels to turn and not hit the 60" deck! Share this post Link to post Share on other sites
608KEB 808 #7 Posted November 27, 2016 (edited) So a 42" plow won't work on a 520H with swept axle without the extension? Will the blade hit the front tires when angled? Edited November 27, 2016 by 608KEB Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #8 Posted November 27, 2016 (edited) 15 minutes ago, 608KEB said: So a 42" plow won't work on a 520H with swept axle without the extension? Will the blade hit the front tires when angled? Yes when angled it hits the front tires unless you extend the blade frame with the kit or the cheap way I did it, by adding a 3-4" extension(I used angle iron) between the angle head and mold board where the retaining pin is, also when the 42" wide is angled the snow/dirt/ect will exit right into/under the tire it's angled to I had to add extensions to to the mold board as well it now measures 50" wide, Jeff. Edited November 27, 2016 by WVHillbilly520H 3 Share this post Link to post Share on other sites
