Mike Nelson
Tired old Kohler K301 needs TLC
Mike Nelson
Hello to all. I have a 1973 Wheel Horse 12 automatic in pretty good shape. It has been in continuous summer use since the day it was new. This machine is only used for lawn cutting in Wisconsin. It spends it's winters inside of a garage that is attached to my house. It has never been left outside when not in use. It has the famous Kohler K series engine, (K301). Other than a replaced fuel pump, and standard tune up items, this tough old engine has never been worked on internally. Over the last few years, I can tell it is has lost some power. It also has begun to use oil (sae 30w) at an increasing rate, Although no signs of smoking. It is also seeping some oil out of the governor shaft bushing.  Because this is such a tough old tractor, and the fact that I have a spare hydro unit, I have decided to rebuild this engine. Heck, it's already got 43 years of use from this tough engine. I am not wanting to just "THROW some rings in there" and call it a rebuild. OH NO! I will do this the right way.
I would love to just get a new Kohler short block and call it a day, but I know they are getting rare now especially trying to match up with my unique spec number. So I will have to do a complete tear down and rebuild. I will leave no stone unturned. I have no knowledge of machine shop procedures, but I should have no problem, to dissemble, clean, have machine shop work done, then reassemble.  The reason I posted this, is to ask if anyone knows of a genuine small engine machine shop, without a bunch of high school kids learning how on my engine.  I have tried in the past to have quality work done at machine shops, and I have discovered that with all my ignorance in this area, I was more informed than most of them. The one place I came to trust is long gone now. I always run this engine full blast when cutting the lawn (wide open throttle) that is why I would like OEM Kohler parts inside. I know getting OEM for something this old will not be easy, but I am much more concerned about finding a trusted and competent machine shop to do quality work. I can find do it yourself machine shop hacks anywhere,
MOST of the members here are well informed, caring and dedicated folks who care about preserving the classic old Wheel Horse. Can you please give me your thoughts on undertaking this rebuild?
Thanks so much
953 nut
:WRS:           Don't live in your area so can't come up with a specific name of a shop. I would suggest talking to the owner/managers of some equipment rental stores to see who they use; they want the work done right and they want it done promptly.
Take a look at this recent thread on engine rebuilding, it will be a good resource.
Good luck and keep us posted as you go along.
Shynon
Talk to your local mechanic shop and see who he uses for his machine shop work. He won't take his work to a machine shop he does not trust to do his work. I have done a dozen or so K series kohler rebuilds with aftermarket engine parts with great success. Besides a quality machining job and a clean assembly will make a quality engine rebuild. And :WRS:
ohiofarmer
 I really cannot say what a rebuild costs, but one way to go is just buy another Horse with the same engine series. My addiction started with a Kohler 10 Raider of 1972 vintage. I bought a second tractor much like yours and a third 12 horsepower manual transmission. What i will probably wind up doing is pick the best engines and sheet metal from all three to make two sweet tractors and another running tractor that will be sold.  I have a Raider10, an Electro 12, and a c-121-8. that will be mix and match.If they all fit together like I think they will.
 Maybe you could do the same. Find a decent runner that may have other issues and swap engines so you can take all the time you need to get your 301 the way you want it.. You certainly do not want to run the risk of working your tired engine and then throw a rod through the engine block. I only have $775 in all my stuff, but I am careful and try to learn from my mistakes.
Sarge
There are a lot of garden tractor pullers in Wisconsin - look some up and find out who they use , any builder that can handle doing mods to that extent on a Kohler engine knows their stuff . I'm lucky , got an old school machine shop nearby that specializes in these engines and will only use Genuine Kohler parts , never anything aftermarket . His prices aren't bad at around $500 if the crank is good...
Sarge
Mike Nelson
Thanks for all the great comments and ideas.
Mike
Coadster32
:WRS:
The engine you describe might not actually need a machine shop, as there's no catastrophic failure. I'd tear it apart, and do some inspecting. If it's not blowing oil/smoking, perhaps a hone, valve lapping, some new seals, new rings, and you're off and running. Obviously you won't know until you get there, but all new parts might not be nessasary. Good luck with it. You've found the right forum.
  • Similar Content
    • aaronthomas57
      By aaronthomas57
      Hello Everyone,
      The information here has been invaluable as far as getting this old wheel horse I purchased back in service. Some parts home made, the motor generator is ripped off a 2013 Yamaha, some salvaged parts.
      I bought this little bastard some months ago, it had to be dug out of the previous owners yard and lifted with a backhoe. It had not ran in about 40 years.
      Thanks for taking a look.
    • Gravely Horse
      By Gravely Horse
      I’ve got a 520xi with a ch20 kohler. It has 982 hours. It runs fine, but after seeing this valve train kit on eBay, I was wondering if there is any harm or need to throw one in it. Any one have insight into this?
    • CasualObserver
      By CasualObserver
      Owners manual for the two cylinder snowmobile engines.
      12 pages 1.38MB
      1970 399 Safari snowmobile model 9-0041 - 2-cylinder
      1970 440 Safari snowmobile model 9-0051 - 2-cylinder
      1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
      1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
    • CasualObserver
      By CasualObserver
      Owners manual for the Single cylinder snowmobile engines.
      12 pages 1.33MB
      1970 295 Safari snowmobile model 9-0011 - 1-cylinder
      1970 309 Safari snowmobile model 9-0021 - 1-cylinder
      1970 309W Safari snowmobile model 9-0061 - 1-cylinder
      1970 355 Safari snowmobile model 9-0031 - 1-cylinder
      1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
    • Jeff-C175
