Sparky-(Admin) 26,688 #1 Posted November 25, 2016 Can I get a bit of info on the 633. Were they electric start or pull start? What Kohler did they have...6hp, or 6.25hp or 7 hp? Thanks. Mike..... Share this post Link to post Share on other sites
rj35hunter 309 #2 Posted November 26, 2016 They were recoil "pull start" and had a Kohler K141 6.3 HP 1 Share this post Link to post Share on other sites
slammer302 2,157 #3 Posted November 26, 2016 Another little fun fact is they came with the battery tray tool box. Share this post Link to post Share on other sites
Shynon 7,728 #4 Posted November 26, 2016 I think the early ones had an updraft carb, and the later ones had the standard Carter Share this post Link to post Share on other sites
Sparky-(Admin) 26,688 #5 Posted November 26, 2016 Thanks guys...going to look at one tommorow. Guy claims it's the 6.25 hp Kohler but has electric start. Mike..... Share this post Link to post Share on other sites
AMC RULES 37,260 #6 Posted November 26, 2016 Did you inquire about the 701's Mike? Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #7 Posted November 26, 2016 37 minutes ago, Shynon said: I think the early ones had an updraft carb, and the later ones had the standard Carter I'm not so sure that's ever been proven as being a constant. I do know there were problems with intake manifolds breaking and I believe the Kohler "fix" was to install the standard side draft Carter "N" & matching governor lever & link in place of the updraft Tillotson. Earliest versions did have a Fairbanks-Morse recoil vs. the Kohler recoil found on the later models. 6 Share this post Link to post Share on other sites
new2horses 288 #8 Posted November 26, 2016 Mine, has the tilloston carb. I don't believe there is room for the carter and even the slimmest air cleaner behind the grill. So my question is how would that have been addressed? Thanks, David Share this post Link to post Share on other sites
Retired Wrencher 7,037 #9 Posted November 26, 2016 Mike I hope it all works out for you. Defiantly pictures wanted when you can. Share this post Link to post Share on other sites
stevasaurus 23,884 #10 Posted November 26, 2016 Sparky...your own list has the 633 listed with a K 141 T 29102A. Share this post Link to post Share on other sites
rj35hunter 309 #11 Posted November 26, 2016 4 hours ago, new2horses said: Mine, has the tilloston carb. I don't believe there is room for the carter and even the slimmest air cleaner behind the grill. So my question is how would that have been addressed? Thanks, David David, I have two 633's one with the original tilloston setup and the other was already converted to the Carter carb with normal round metal air filter housing setup. Then to convert to Carter you take off the special elbow then normal setup bolts up like any of the other models. Share this post Link to post Share on other sites
Sparky-(Admin) 26,688 #12 Posted November 26, 2016 Well I bought it....going to start a new thread on its homecoming! Mike.... 1 Share this post Link to post Share on other sites
wallfish 20,733 #13 Posted November 26, 2016 Ooooo, Mike's herd is growing. Seems like he's back in the saddle actively hunting again 1 Share this post Link to post Share on other sites
