Countdown To Christmas!
tommyg
oil level
tommyg
The manual for the d-180 calls for 6 quarts of oil in the transmission. When I do that, it's well above the full line. When I start the tractor, it seems normal. If I only fill it to the full line, then start the tractor, it's way below the full line. What's right? I've been using the 6 quart recommendation on a "dry" transmission (assuming all the oil is drained down to the transaxle) and have not had any problems, but I don't want to create one either. Any thoughts?
pfrederi
I would go with the dipstick.  The pump and manifold lines may drain down some also you have to fill the hydraulic cylinders..  I fill it to eh dipstick mark then run it for a while and see if it needs more.I do not see any downside to being somewhat over full other than some being pushed out the dipstick
Sarge
My D does that exact thing with the oil level climbing - I suspect a very small leak somewhere that is allowing the pump or cylinders to drain back into the transaxle and increasing the oil level .
Sarge
tommyg
Wouldn't it drain back normally? I'm going to have to check the level right after running it and after sitting for awhile.
Sarge
Normally , I'd say no - it shouldn't drain the oil back to the axle housing if everything is tight and sealed well , especially the pump and spool valve/cylinders .
Sarge
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Brandon Byers
      By Brandon Byers
      I know I'm half a year ahead of schedule!
      I picked this 1974 D-180 up early last year. It had a pretty hard life, and the previous owner gave his best attempt at keeping it alive. Hydro was strong so I serviced it and put it to work mowing all year. I decided if it would make it through the season then it would get some TLC. By fall it was burning about a quart of oil an hour but it made it. I have no clue how many hours are on it, every hole, bushing, bearing on this tractor is pooched. If you look closely, somebody used two 1" NPT Pipe Flanges to rebuild the mounting points for the upper 3 point cylinder. Hey it works!
      I rebuilt the steering gearbox and re-bushed the front axle along with making new spindles.
      I had the 482 Kohler bored .20 over (it was .10 over already) and gave it a rebuild with the intention of putting it back to work on snow duty.
      I then dawned on me that this tractor will be 50 years old next year - and these old D's are becoming harder and harder to find anymore. So I decided to customize it a bit and go for what a maybe a dealership would offer for a 50th anniversary model if Wheel Horse was still in business today (In another universe, maybe!)
      As D's aren't known for their looks - and I can't leave anything alone. I took approximately 2 Inches out of the grille and bezel.
      I updated most of the wiring and lights. Gave it a new set of Carlisle Ags along with Vredestein front ribs. It got a new seat and I painted all the accents aluminum.
      I patched, rebuilt the 48" deck and put new blades, wheels, and hardware on it. The Blade & 3 point scoop somebody adapted to it also got some attention.
      Lastly I stripped it most of the way down and painted it with IH red acrylic urethane enamel.
      I always forget to take pictures during my projects but here's a few:
      Before:
      After:
      Thanks for reading!!
    • Crazy Old Red Horse
      By Crazy Old Red Horse
      Barn find 1975 D180. 608 original hours. Tractor and 48” belly mower look to be still in their original paint. Rear 60” finish mower looks like it has had one coat of new paint added at some point. Open to trades. Please email me with any questions or for additional photos. 35 miles north of Pittsbugh.
