AHenry014 127 #1 Posted November 8, 2016 Hey all, I have a 1984 GT1100 with the 11hp briggs on it that i dont care for. Its hard to start, even with a clean carb, and smokes like the dickens when cold. It also seems down on power compared to the 10hp Kohler i am used to. That said, I have a great running 10HP Kohler Magnum from a 1988 310-8 that i would like to swap on. As far as i can tell, it should physically bolt right up as it was on the 310-8. I kept everything that looks important from the 310. I am, however, concerned with the wiring. When i was disassembling the the 310-8, i grabbed the entire chassis harness just in case i needed it if/when i decided to swap the engine to the GT. I would prefer not to have to swap the harness, but will if i need to, assuming both tractors use all the same safety switches (normally open vs normally closed). I can tell that the Kohler used a regulator/rectifier of sorts, and has a couple fuse holders that my GT does not. Anyone have experience with this particular swap and can give me a couple pointers? Thanks Share this post Link to post Share on other sites
Wishin4a416 2,192 #2 Posted November 8, 2016 (edited) I put a 14 Kohler on a 1142. It was however a K series which are easy for me to wire. The electric is my weak point. I didnt think the 10 Kohler Magnum had a regulator. I thought there were only diodes to control the voltage. My 87 was like that anyway. And it overcharged bad. The 10 will go right on that tractor with no mods. except wiring and throttle and choke routeing. Good Luck! And welcome to the forum! Edited November 8, 2016 by Wishin4a416 3 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,524 #3 Posted November 8, 2016 The spec number on the M10 should identify the charging system. There is a chance the early 1988 models used the 3amp dual system like the B&S and then went to the 15 amp regulated system. Garry 1 Share this post Link to post Share on other sites
SALTYWRIGHT 861 #4 Posted November 8, 2016 I AM PUTTING TWO DIESELS IN MY GT-1800 RUSS 1 Share this post Link to post Share on other sites
AHenry014 127 #5 Posted November 9, 2016 18 hours ago, Wishin4a416 said: I put a 14 Kohler on a 1142. It was however a K series which are easy for me to wire. The electric is my weak point. I didnt think the 10 Kohler Magnum had a regulator. I thought there were only diodes to control the voltage. My 87 was like that anyway. And it overcharged bad. The 10 will go right on that tractor with no mods. except wiring and throttle and choke routeing. Good Luck! And welcome to the forum! I have a pair of Ag's coming my way. This picture excites me for that! 16 hours ago, gwest_ca said: The spec number on the M10 should identify the charging system. There is a chance the early 1988 models used the 3amp dual system like the B&S and then went to the 15 amp regulated system. Garry I will take a look at the wiring harness i yanked off. I remember pulling a silver box off the right side engine "compartment" near the PTO lever, near where they stick the fuse holder(s). Not sure what else that would be besides a R/R. Share this post Link to post Share on other sites
Wishin4a416 2,192 #6 Posted November 9, 2016 2 hours ago, AHenry014 said: I have a pair of Ag's coming my way. This picture excites me for that! I will take a look at the wiring harness i yanked off. I remember pulling a silver box off the right side engine "compartment" near the PTO lever, near where they stick the fuse holder(s). Not sure what else that would be besides a R/R. I believe that silver box would be a relay Share this post Link to post Share on other sites
AHenry014 127 #7 Posted November 9, 2016 interesting. how do i go about determining which charging system it features? Share this post Link to post Share on other sites
AHenry014 127 #8 Posted November 9, 2016 did some more research, per this parts list: https://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/21-10k805-310-8-toro-310-8-garden-tractor-1988/electrical-system_3/ it is in fact a relay. Comparing wiring diagrams found on this site, it appears this relay is only used for the oil swith/test light business. I wont be fitting that system. It looks like this shouldnt be too bad a swap. The wiring should be more or less cut and splice from the newer harness. Thanks all! Will report back when i get to the project. Share this post Link to post Share on other sites
Wishin4a416 2,192 #9 Posted November 9, 2016 4 hours ago, AHenry014 said: interesting. how do i go about determining which charging system it features? If you dont find a regulator then I would say it is the unregulated system. The regulator on my 312 Magnum is located on the left side of the engine shroud not to far from the carb. Looks like this. Like Garry mentioned, there were the 2 systems in 88 Share this post Link to post Share on other sites
AHenry014 127 #10 Posted November 10, 2016 ah, thank you for that. I dragged the engine out of the corner and took a peek. It appears as though it does have a regulator, though i do not think that really changes the wiring all that much, looking at the diagrams. Should be able to hook it up nearly the same as the current engine is and shes a runner. Share this post Link to post Share on other sites
AHenry014 127 #11 Posted January 30, 2018 Posting back for future reference, i did not actually end up doing this swap. The briggs just kept running better and better the more i used it. It runs fabulously now, so i see no reason to remove it from a perfectly good working tractor. I did end up using the M10 in a 314H frame. It works wonderfully, but i don't think i care for the hydro system. I prefer the clutch. 2 Share this post Link to post Share on other sites
Sarge 3,465 #12 Posted January 31, 2018 Briggs engines are known for sticking their rings if they sit a lot - most times some fresh oil and working it hard will knock them loose and clean out the carbon buildup. Just a few oil changes on short intervals might remove excess carbon as well as not letting it idle a lot. All these engines are built to run at a load and wide open throttle - so keep that in mind. Sarge Share this post Link to post Share on other sites
AHenry014 127 #13 Posted January 31, 2018 thank you for the heads up. I realized most of my hard starting issues were due to a misadjusted choke. Once i took care of that, it was just a matter of use to get the smoking to cease. Share this post Link to post Share on other sites
