Silverado 2 #1 Posted October 27, 2016 Silverado Today 8:27 PM I have a 1990 520-H. I cleaned it about 1 1/2 weeks ago and stayed away from the electrical wires, but I cleaned by the neutral safety switch. The switch is located on the forward and backward shaft. It's 4 months old. The tractor is completely dead. My son directly jumped the solonoid and starter and it cranked the engine. Could it also be the starter relay? Does anybody have any suggestions? Share this post Link to post Share on other sites
maxiblue 352 #2 Posted October 27, 2016 Do you have a neutral safety switch some where on that tractor? Either on a shifter handle or under a seat, or some other place if so just short the wires together and by pass it. This may be one problem other then that I don't know, I don't know any thing about a 520 sorry. Share this post Link to post Share on other sites
WNYPCRepair 1,924 #3 Posted October 27, 2016 Make sure you didn't accidentally unplug the neutral switch when you cleaned, PTO is off, and you are sitting on the seat. I forget, does the brake have to be on on the 520? 1 Share this post Link to post Share on other sites
Ed Kennell 47,239 #4 Posted October 27, 2016 Did you check the fuses? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,483 #5 Posted October 27, 2016 There are 3 switches that control the starter circuit relay on the 1990 520-H. ignition switch 1/2 of the pto switch neutral switch Garry 3 Share this post Link to post Share on other sites
TDF5G 2,074 #6 Posted October 27, 2016 2 hours ago, gwest_ca said: There are 3 switches that control the starter circuit relay on the 1990 520-H. ignition switch 1/2 of the pto switch neutral switch Garry This is what I would check first. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #7 Posted October 28, 2016 Double check that neutral switch on the the 520 I bought this spring I went crazy tracking down an electrical problem that was mechanical, the actuator was missing top pic, new second pic,Jeff 2 Share this post Link to post Share on other sites
Silverado 2 #8 Posted October 28, 2016 Thanks for all of your help. The problem was in the start relay upon checking the power. I had to assume that the start relay was bad. After tapping it three or four times, the tractor now starts. I will be getting a new start relay in the next few days. 2 Share this post Link to post Share on other sites
