WHwest8597 85 #1 Posted October 20, 2016 The shed we have was build in 1982 and is a barn style with short side walls 12 x 16 in size. The shed needs to be replaced, and looking for some ideas. I know that if we go with a new shed, I would probably go with the barn style again, but what high sides this time. I don't want to go any bigger than 12 x16. Going smaller 10 x14 to avoid taxes is just loosing to much space. I have also considered adding on to our 24 x 32 garage. Any suggestions would be appreciated. Share this post Link to post Share on other sites
Jerry77 1,218 #2 Posted October 20, 2016 27 minutes ago, WHwest8597 said: I have also considered adding on to our 24 x 32 garage If you did that you would only have 3 walls to build - and with an access door to the garage you might pick up some extra space to park your WH tractors in... 2 Share this post Link to post Share on other sites
953 nut 64,401 #3 Posted October 20, 2016 Check with your insurance agent and building department to see if either option has an advantage. Building an addition can be a bit more difficult because you want everything to be the same height, color, roofing etc. so it won't stand out as being an "addition". 1 Share this post Link to post Share on other sites
Jerry77 1,218 #4 Posted October 20, 2016 57 minutes ago, 953 nut said: building department Never entered my mind - live out in the country and don't have building codes etc...don't need a permit to build etc... no zoning laws either..(that could be a problem if someone wanted to start a hog farm tho ) 1 Share this post Link to post Share on other sites
AMC RULES 37,254 #5 Posted October 20, 2016 (edited) I feel your pain broman... well past the stage of needing a new magic shed here too. Edited October 20, 2016 by AMC RULES 2 Share this post Link to post Share on other sites
jackhammer 550 #6 Posted October 20, 2016 1 hour ago, AMC RULES said: I feel your pain broman... well past the stage of needing a new magic shed here too Me thinks you have to dig deeper Craig 2 Share this post Link to post Share on other sites
AMC RULES 37,254 #7 Posted October 20, 2016 ... about three stories below grade. 1 Share this post Link to post Share on other sites
squonk 45,664 #8 Posted October 20, 2016 1 hour ago, AMC RULES said: ... about three stories below grade. Build up. You get a nice view ( maybe depending on what your neighbor looks like! ) put some lawn chairs and grill on the roof. Pretend it's a NYC penthouse! 2 Share this post Link to post Share on other sites
RedRanger 1,470 #9 Posted October 20, 2016 No building codes and no inspectors.....Add on to the garage! 1 Share this post Link to post Share on other sites
JimD 3,347 #10 Posted October 21, 2016 The 12 x16 shed you have gives you 192 square feet of space. Adding on to the garage you can achieve the same floor space with a 6x32 addition. The cost of the addition will probably be higher with the foundation and floor materials and labor, etc, so it's really allup to you and your budget what you can do. Good luck and keep us up on your project. Share this post Link to post Share on other sites
