Rob R
Onan 520 H 20HP Issues
Rob R
Hi guys have a friend with a 520H (1988) with a dead engine, he claims a few months back he went
to crank it and it made a funny sound then no workee anymore..... I took a look at It quickly this
afternoon definitely something broken internally, cranks but free-wheels with no compression nothing
coming out the exhaust.... I was very surprised that one cylinder wouldn't push some exhaust
or compression out.... is I possible BOTH connecting rods are broke or maybe the Crank????
Have you seen this before?  it is worth fixing....? I have rebuilt single cylinder engines prior and one
B&S dual lung..... what scares me is the availability and cost of ONAN parts????
Engine according to him ran fine prior, he said no BIG BANG just a funny noise...... I looked at the
meter has just under 700 hrs on it. Thanks for any information or experience you can provide.
Dirtdog524
Did you do any kind of compression check / At the very least, pull the front head and take a look.
fast88pu
Possibly valve seat has let loose rob
Rob R
I had no tools so this would have to be in the future....
Yes maybe the valve seals also Kyle, definitely some serious work here.....
Ed Kennell
May be a candidate for a $600 HF Predator.
cleat
I wonder if it sheared the key on the flywheel and it is now just spinning on the crank.
When you crank it, does the PTO side turn as well ?
Rob R
I didn't take notice, but you may well be on to something here, Cleat this makes some good sense to me....... so what you are saying is that flywheel is spinning but Not the crank since the starter engages the flywheel teeth? Is this a difficult repair, what has to be removed?   Thanks
Edited by rgrottk
lynnmor
Grab the PTO behind the belt and turn it by hand, if it turns hard that is a good thing.
As far as the flywheel being loose, it all depends on the condition of the taper in the flywheel and on the crank that will determine the costs.
Rob R
Do  you think something jammed-up internally  and this caused the Key to break, have you ever seen this key break but the rest of the engine is okay..... Thanks.
cleat
It may not be that, just an easy thing to check.
Actually, I wonder if the engine is turning at all or just the starter.
We need a little more info. to make more informed decisions.
Cleat
  • Similar Content
    • 84Workhorse
      By 84Workhorse
      '97 520H for sale; Reason for selling; I bought it about 6 years ago when my GT-1800 engine died which I will be re-powering so I have too many tractors and something has to go.
      I can provide more information and pictures if needed.
      Details:
      All shown in pics included in the price. 998 hours; Engine is in good condition 48 in. mowing deck in sound condition, no rust through 42 in. SS snow blower, I used it twice in 5 years, tire chains go with it 42 in. snow blade sat in my storage shed for the last 35+ years. Rear axle bracket does not go with it b/c I have a tiller for my GT All lights and gauges work with the exception of the engine load gauge. The vacuum nipple is broken off.
    • Chaz54
      By Chaz54
      Full set of NOS Wheel Horse Chrome Embossed Hubcaps for a 520H.
      Let me know if you have questions, need more information, pictures, etc.
      Buyer pays shipping. Located in Washington, MO 63090
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
