314hydro 0 #1 Posted January 5, 2009 ...then all of the sudden i heard a popping noise, now the lever is easier to move but my tractor is alot slower when i have the lever all the way forward to unleash the ponies, but i think a deere could out run me right now....btw this is after i had numerous problems getting my 48 dozer blade mounted, i love the eaton 1100 but i hope this isn't a serious issue, any suggestions.....help!!!!!! :hide: Share this post Link to post Share on other sites
Rollerman 291 #2 Posted January 5, 2009 Eric give all your linkages a good look over to make sure nothing is obviously broken. I think you said yours was missing a fender...so that should be easy to checkover. Also pull the plate at the base of the dash tower & check the linkages under there. Sounds like you had something binding IMOP & broke in the linkage. Share this post Link to post Share on other sites
