mikehusky455 16 #1 Posted October 17, 2016 just wondering if someone can take a close up pic of the valve lever,to raise/lower 3pt hitch.,looks like lever on a woodsplitter.,its on my 69 wh gt14 thanks.also a pic of the inside of steering wheel for same tractor. Share this post Link to post Share on other sites
953 nut 69,073 #2 Posted October 17, 2016 Hope these help. 1 Share this post Link to post Share on other sites
mikehusky455 16 #3 Posted October 18, 2016 yes thanks,now just need to see what the end part of that lever looks like,just trying to see if I can come across something that will work if I cant get/find the original.but no need to take that cover plate off ,I'm shure,someone has a pic.,i mite also look for a parts list that mite show something close enough.again thanks. 1 Share this post Link to post Share on other sites
953 nut 69,073 #4 Posted October 18, 2016 @Aldon did an extensive post on his two GT-14 rebuilds, bet he has a photo. I can't say for sure, but i think I recall it being a regular threaded filling like a 5/16 bolt; been a few years since I was in there. 3 Share this post Link to post Share on other sites
Aldon 4,832 #5 Posted October 18, 2016 (edited) The knob end of the lever on the last one I did was not threaded. I used a dremel to shape it and a die to thread it to add a knob. The end that attaches to the control valve is attached via a small cotter key. I'll look through my photo archive to see if I can find a detailed pic but I do not recall documenting it as my focus was on archiving the more difficult assemblies. Edited October 18, 2016 by Aldon 1 Share this post Link to post Share on other sites
ztnoo 2,302 #6 Posted October 18, 2016 I have that frame cover plate off watching what has been going on with a slow, but steady hydraulic leak coming from the control valve. The pics were no problema. Should give you a good idea of what you need to do and how it assembles. 1 Share this post Link to post Share on other sites
Aldon 4,832 #7 Posted October 18, 2016 20 minutes ago, ztnoo said: I have that frame cover plate off watching what has been going on with a slow, but steady hydraulic leak coming from the control valve. The pics were no problema. Should give you a good idea of what you need to do and how it assembles. Excellent pics Steve. we should consider adding links to stuff like this and the thread you did on axle hubs and woodruff keys to the GT14 restomod thread and make a one stop repository for GT14 seekers of knowledge. Sure seems to be enough on this model that a subforum topic might work. 1 Share this post Link to post Share on other sites
mikehusky455 16 #8 Posted October 18, 2016 thanks for the pics,i should be able to make one up,i repair a lot of mowers for people,and got lots of small diameter,rods with the holes already in the end.came off a lot of different controls for brakes/linkages ect.thanks again Share this post Link to post Share on other sites
