RickF
exhaust stack
fast88pu
Nope no unions. Just tighten it up good. Could weld if it's an issue or use a locking nut
bmsgaffer
@fast88pu I think @USHorse means threaded joint.
Yes, those iron pipe pieces are threaded together but they are not a threaded union (see below). ;) The person that made the stack on my 854 tack welded the joints, it stays vertical but the only way I will be able to remove it is to cut the muffler off (they buggered up the threads)... just FYI.
Edited by bmsgaffer
