Team70R
Deck lift handle lock release
Team70R
Anyone know how to replace the spring at the bottom of the manual lift deck handle that puts pressure on the lock to hold up the deck in its highest position? I've already removed the rubber grip at the top.
Wes
gwest_ca
What model of tractor?
Garry
Team70R
Sorry, knew I was forgetting something!! It's a 655
Ed Kennell
Go to the operators manual for your tractor. You will find the detailed parts dwg for the lift arm assembly.    I tried to paste the link, but it failed.
There is a block and roll pin at the bottom, but I can not remember if you have to remove the entire rock shaft / lift lever to get to it.
Edited by Ed Kennell
KC9KAS
I have fixed a couple, but can't remember/explain it....seems there was a roll pin I had to drive out of a block at the bottom, disassemble, replace the spring and reassemble.
Team70R
Thanks! That atleast gives me somewhere to start!
gwest_ca
The parts manual may help
Garry
Ed Kennell
Thanks Garry,  some days I am smart enough to copy and paste and other days.......:confusion-helpsos:
Team70R
Got it!! Thanks for link to the manual. Definitely a life saver!!
  • Similar Content
    • Jayzauto
      By Jayzauto
      Toro - WheelHorse Deck Chutes available.  Fit 42” & 48” Side Discharge Decks.  These are New & Restoration Quality.  I have 2 available.  $50ea/BRO
    • 87buickt
      By 87buickt
      Listing for a friend, late 70s I believe D200 deck and plow. Been sitting for a while, make reasonable offer, friend also has tons of literature he may part with, if Interested let me know
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
    • BrianKoch
      By BrianKoch
      Gentleman, I’m in need of:
      Mower deck rod lift part # 6699
      (I really just need the rod, not the trunnion or nut)
      Thank you!
