Bach-Ed
Is this Kohler block any good
Bach-Ed
Last year this K241 threw a rod.  And as it went it damaged the bore.  I later heard that some lower damage can be tolerated when rebuilding.  So is this still a usable block or is it only fit to be a boat anchor?
JAinVA
If that damage is below the  piston skirt bottom at bottom dead center and there are no radiating cracks from the damage you should be good to go.The piston doesn't travel all the way to the bottom of the bore anyway.If you won't have to put a lot of money into I say go for it,JMHO,JAinVA
Edited by JAinVA
953 nut
If it is not in need of being bared I would think it is going to be OK. You may want to have it magnafluxed to be sure there are no cracks.
JAinVA
As Richard says you could get the block magnafluxed.That is the best way to make sure that the damage hasn't let unnoticed cracks cause a problem.If that service isn't available to you, try a dye penetrant test.While not as good magaflux it can detect cracks.Again if little money is at stake and you know the risks button her up and see what happens.These old Kohlers are some of the toughest air cooled engines ever built.JMHO,JAinVA
Edited by JAinVA
oldredrider
I've successfully rebuilt blocks in much worse shape than yours. Sleeving the cylinder is another option if necessary.
Howie
Knock the sharp edge off of that hone it or bore it and use it. My K301 is similar to that and has been in service since 1985. It could be
sleeved as mentioned above.
WH nut
Run her
  • Similar Content
    • Gravely Horse
      By Gravely Horse
      I’ve got a 520xi with a ch20 kohler. It has 982 hours. It runs fine, but after seeing this valve train kit on eBay, I was wondering if there is any harm or need to throw one in it. Any one have insight into this?
    • CasualObserver
      By CasualObserver
      Owners manual for the two cylinder snowmobile engines.
      12 pages 1.38MB
      1970 399 Safari snowmobile model 9-0041 - 2-cylinder
      1970 440 Safari snowmobile model 9-0051 - 2-cylinder
      1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
      1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
    • CasualObserver
      By CasualObserver
      Owners manual for the Single cylinder snowmobile engines.
      12 pages 1.33MB
      1970 295 Safari snowmobile model 9-0011 - 1-cylinder
      1970 309 Safari snowmobile model 9-0021 - 1-cylinder
      1970 309W Safari snowmobile model 9-0061 - 1-cylinder
      1970 355 Safari snowmobile model 9-0031 - 1-cylinder
      1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
    • Jeff-C175
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
