elcamino/wheelhorse 9,363 #1 Posted October 7, 2016 Where can I purchase a replacement carb for a 1988 416-8 . Partstree did not have . Please help. Share this post Link to post Share on other sites
Jerry77 1,218 #2 Posted October 7, 2016 Saw one on the web fpr $ 379.99 If you want to spend that much it is at:http://randysengine.repair/products/oem-genuine-onan-146-0495-carburetor-n52m-p216g-p218g Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #3 Posted October 7, 2016 @Jerry77 Thanks for the info . My 416-8 has a Kohler m16s motor. It has a Walbro carb on it now, but I don't think they are made any more. Running in to a wall. Tried Jack's small engine. Partstree, Repair parts clinic . I think my card is beyond repair so I am looking for a replacement. There has to be something out there. Share this post Link to post Share on other sites
Jerry77 1,218 #4 Posted October 7, 2016 I just assumed that it was an Onan - even with the problem you have, I would rather have the Kohler... Share this post Link to post Share on other sites
Sparky-(Admin) 26,284 #5 Posted October 7, 2016 I have had great luck with the new carbs sold on EBay...check out EBay seller isavetractors or go to isavetractors.com. You can get a brand new carb for an M16 for $60. I have bought three of these carbs, maybe they are knockoffs, but they worked perfectly right out of the box. Mike...... Share this post Link to post Share on other sites
Jerry77 1,218 #6 Posted October 7, 2016 Jim - would this work??? http://isavetractors.com/carburetor-bundle-pack-for-k321-k341-m14-and-m16-engines/ aftermarket for m16----90 bucks........... 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,284 #7 Posted October 7, 2016 HAHA...we think alike Jerry! Mike...... Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,928 #8 Posted October 7, 2016 Yes, a '88 would have the M16 Kohler. But, if it was an Onan, the intake gasket will, over time, become brittle and begin to leak causing what appears as a carb problem. If it was an Onan, then replacing the intake gasket will solve that problem. But, as mentioned, a '88 416 will have the Kohler in it. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #9 Posted October 7, 2016 Thanks guys that is a big help. Going to order tonight so I can get the ole horse back into shape. Share this post Link to post Share on other sites
kasey54 305 #10 Posted October 8, 2016 Norman at isavetractors.com will fix you right up. I have bought a half dozen or more carbs from him for the Kohlers. Share this post Link to post Share on other sites
clueless 3,437 #11 Posted October 8, 2016 13 minutes ago, kasey54 said: Norman at isavetractors.com will fix you right up. I have bought a half dozen or more carbs from him for the Kohlers. Share this post Link to post Share on other sites
Pollack Pete 2,273 #12 Posted October 8, 2016 11 hours ago, Sparky said: I have had great luck with the new carbs sold on EBay...check out EBay seller isavetractors or go to isavetractors.com. You can get a brand new carb for an M16 for $60. I have bought three of these carbs, maybe they are knockoffs, but they worked perfectly right out of the box. Mike...... Sparky's right.I bought one for one of my C-195's.Works great and was a direct fit. Share this post Link to post Share on other sites
Wishin4a416 2,610 #13 Posted October 8, 2016 Can it be rebuilt Jim? Are kits available for the Walbros? I have rebuilt 3 Kohler carbs and rebushed the shafts with good sucess. Share this post Link to post Share on other sites
clueless 3,437 #14 Posted October 8, 2016 Just a heads up, I bought a carb for a k181 from russos on ebay awhile back, 39.99. The fuel inlet was a weird 3/16 inverted thread, I tapped it with a 1/8 tap and it works just fine, The ones from Norman, at isavetractors cost a little more but no tapping, also if you have a question or a problem you can call and talk to HIM, big plus in my book. Search russos here. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #15 Posted October 9, 2016 @Wishin4a416 The Winder family is cursed when it comes to carbs. If it don't work right do not try to fix it . We waste money , time and end up buying a new one anyway. I have cleaned off the work bench , laid down a clean tee shirt , nailed it down with wood edges , had nice bright lighting , all the correct tools and ended up losing new little parts, broken little parts and come away with a migraine. Therefore if anyone wants a couple of used carbs that may need rebuilding I have them. One from a 310-8 , a 416-8 and one from a 10hp Tecky ( the electronic crapole was bad ). Share this post Link to post Share on other sites
