Elkskin's mower junkyard 1,117 #1 Posted October 3, 2016 well i knew one of the b80s engines was done for because what my boss said. so i was messing with the engine i put on the workhorse and it did seem low on compression. well got it to pop that was it so pulled head found part of piston gone looks like she broke a ring. so heres what i am going to try i am going to put the jd 208 engine on the workhorse changing pan now. 1 Share this post Link to post Share on other sites
Wheel-N-It 2,978 #2 Posted October 4, 2016 Glad to hear you didn't give up! 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #3 Posted October 4, 2016 i put the b80 pan on the jd 208 engine due to oil drain being in way. i bolted it on and due to fact i dont have wiring done i hooked it up to battery out of my old truck she spun over a bit and fired up. runs sweet needs minor adjusting. didnt see any smoke but its dark lol. i like the jd shroud because regulator or rectifier what ever you want to call it is right on the shroud 3 Share this post Link to post Share on other sites
Wheel-N-It 2,978 #4 Posted October 4, 2016 Cool that you got it running tonight. Hopefully you can get some more stuff done on it tomorrow 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #5 Posted October 4, 2016 even if it didnt pan out like that i got 2 k181 pull start engines. but plan is put the newer look k181 on the commando 800 and the older k181 on dads 753 1 Share this post Link to post Share on other sites
Retired Wrencher 6,457 #6 Posted October 4, 2016 craftsmanmower Good luck with the trans plant hope it all works out for you. 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #7 Posted October 4, 2016 already making attack plans for the commando 800 too. needless to say it will be a good horse when done too. it may get a plow also. Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #8 Posted October 4, 2016 (edited) i messed up in video called a tecumseh a kohler lol Edited October 4, 2016 by craftsmanmowerfreak Share this post Link to post Share on other sites
Wheel-N-It 2,978 #9 Posted October 5, 2016 (edited) Looks like you've got alot of useful parts for alot of good projects Edited October 5, 2016 by Wheel-N-It 1 Share this post Link to post Share on other sites
