clueless 3,347 #1 Posted October 1, 2016 This might be a moot point but I currently have three K181's and two K161's. The governor arm on all five have two holes at the top. All of the carburetors have three holes in the throttle connection. Almost all five are hooked up differently.A couple in the top hole of the governor and the rest in the bottom hole of the governor linkage and some are hooked up to the carb in the first hole closest to the block and some in the second or third hole. Is there a correct way? Just curious. Share this post Link to post Share on other sites
pfrederi 19,783 #2 Posted October 1, 2016 (edited) Last hole in the throttle 5th in Governor Edited October 1, 2016 by pfrederi Share this post Link to post Share on other sites
clueless 3,347 #3 Posted October 1, 2016 Thanks, I have those instructions they are for the big block. The ones I have only have the two holes in the top of the governor arm. Also when you say the last hole in the throttle there are three which do you consider the last hole? Share this post Link to post Share on other sites
pfrederi 19,783 #4 Posted October 1, 2016 small block Share this post Link to post Share on other sites
