T-Mo-(Moderator) 4,742 #1 Posted September 20, 2016 I made these stud adapters to make changing rear tires on my garden tractors a bit easier. Just take a couple of fine thread 7/16 bolts (7/16-28 UNF, I believe) and cut off the heads. Screw them into the hubs finger tight until they're snug and it makes aligning and mounting rear tires a lot easier. 11 1 Share this post Link to post Share on other sites
wedge 80 #2 Posted September 20, 2016 I MAKE THOSE ALL THE TIME FOR PUTTING TRANNYS IN. ONE OTHER THING TO HELP YOU IS TAKE A HAK/SAW AND PUT A SLOT IN THE END SO YOU CAN USE A SCREW DRIVER TO PULL THEM OUT IF THY STICK . 3 Share this post Link to post Share on other sites
bmsgaffer 2,069 #3 Posted September 20, 2016 (edited) Also there's these for those that are interested. I love them, they are SO handy! @rmaynard Edited September 20, 2016 by bmsgaffer 4 Share this post Link to post Share on other sites
WHX?? 54,501 #4 Posted September 20, 2016 If B-100 ever gets them in stock again...never mind I see he has now...my bad Bob ... off to order a set! Share this post Link to post Share on other sites
Jerry77 1,218 #5 Posted September 21, 2016 On 9/20/2016 at 7:53 AM, T-Mo said: I made these stud adapters to make changing rear tires on my garden tractors a bit easier. Just take a couple of fine thread 7/16 bolts (7/16-28 UNF, I believe) and cut off the heads. Screw them into the hubs finger tight until they're snug and it makes aligning and mounting rear tires a lot easier. Just now, Jerry77 said: I made these stud adapters to make changing rear tires on my garden tractors a bit easier. Just take a couple of fine thread 7/16 bolts (7/16-28 UNF, I believe) and cut off the heads. Screw them into the hubs finger tight until they're snug and it makes aligning and mounting rear tires a lot easier. Can't believe I have been struggling with these rear tires on mine ---my poor old brain couldn't see the woods for the trees...thanks much for the tip--best one I have had for awhile. 1 Share this post Link to post Share on other sites
Lee1977 7,544 #6 Posted December 20, 2020 On 9/20/2016 at 7:53 AM, T-Mo said: I made these stud adapters to make changing rear tires on my garden tractors a bit easier. Just take a couple of fine thread 7/16 bolts (7/16-28 UNF, I believe) and cut off the heads. Screw them into the hubs finger tight until they're snug and it makes aligning and mounting rear tires a lot easier. You only need one, then turn it to the top and the others line up. 3 Share this post Link to post Share on other sites
bc.gold 3,406 #7 Posted December 21, 2020 On 9/20/2016 at 6:53 AM, T-Mo said: I made these stud adapters to make changing rear tires on my garden tractors a bit easier. Just take a couple of fine thread 7/16 bolts (7/16-28 UNF, I believe) and cut off the heads. Screw them into the hubs finger tight until they're snug and it makes aligning and mounting rear tires a lot easier. I taper the head then cut a slot for a screw driver, makes removing the stud much easier. I posted this tip a couple of years ago. Used one stud positioned at 12 o'clock. Share this post Link to post Share on other sites
Curmudgeon 28 #8 Posted December 31, 2020 I went one step farther. Screwed Grade 8 bolts through from the back, fully converting them from bolts to studs and nuts. MUCH easier. Also gave me a nice option of fancy lug nuts to dress things up a bit. 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #9 Posted January 1, 2021 4 hours ago, Curmudgeon said: I went one step farther. Screwed Grade 8 bolts through from the back, fully converting them from bolts to studs and nuts. MUCH easier. Also gave me a nice option of fancy lug nuts to dress things up a bit. On 9/20/2016 at 10:34 AM, bmsgaffer said: Also there's these for those that are interested. I love them, they are SO handy! @rmaynard 3 Share this post Link to post Share on other sites
