Tractorstien
D-180 won't go in reverse
Tractorstien
My 74 d-180 automatic works fine except for reverse. When put in reverse I have to throttle all the way up and then it backs up as slow as a snail. What do i need to do to fix this? Please help.
Tractorstien
Ok, gonna try that this evening or tomorrow. Thank you.
Tractorstien
Well adjusted the linkages, didn't help. Then I undid the linkages and pushed the transmission lever all the way back, still goes slowly. Any other suggestions?
oldredrider
Sounds like you're gonna have to start checking valves and springs. See the trouble shooting guide posted above.
pfrederi
:text-yeahthat:
Tractorstien
Changed filter and it is working better, so now I will change the oil and filter again after a few hours of running it. It did sit outside for 6 years and didnt have the filter and oil changed in 9 years or more.
Tractorstien
Pull drive motor to clean screen filter as well and now nothing works, help
pfrederi
Did you put in new O rings and backer rings between the manifold and the motor? did they seat correctly??
Does the midmount lift work??
Tractorstien
Got it working now, the pistons behind the swash plate was messed up
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
