Vrocko 0 #1 Posted August 26, 2016 I have a 75 B-80.Trying to replace the bearings in the main drive pulley.What direction do i drive the shaft out of the spindle. Share this post Link to post Share on other sites
daveoman1966 3,884 #2 Posted August 26, 2016 What mower deck are you working with? 36" 42" Are they cast iron spindles, or made of alum / pot metal? 1 Share this post Link to post Share on other sites
Vrocko 0 #4 Posted August 27, 2016 Sorry Daveoman1966 the site would not let me respond. It's a 36 deck. It's cast iron. I got the sleeve out of the spindle. How do I go about removing the bearings.Heres a pic. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #5 Posted August 27, 2016 That looks like the 103119 bearing that Toro no longer carries. Still available from others including Napa https://www.rcpw.com/search/?quest=103119 It comes with the shaft. Check a parts list if you know the model number of your deck. Garry 1 Share this post Link to post Share on other sites
daveoman1966 3,884 #6 Posted August 27, 2016 EBAY HAS THEM TOO.. JUST SEARCH ON BEARING 103119. AROUND $40 BUX EACH...;SET OF 3 FOR $80 OR SO. THERE IS A RIGHT AND WRONG WAY TO PRESS THE BEARING BACK INTO THE HOUSING....NOTE THE LOCATION OF THE "RING-AROUND-THE BEARING". iT MUST BE ON THE TOP SIDE OF THE HOUSING 1 Share this post Link to post Share on other sites
Vrocko 0 #7 Posted August 28, 2016 Thanks for the help. I'm well on my way to resurrecting this family heirloom. Share this post Link to post Share on other sites
