Live4outdoors 151 #1 Posted July 28, 2016 I have in the works a 753, but just scored a 702 roller and didn't know what all is different on the two tractors since they look identical. I like the rustic dash plate better on the 702 and the engine should be the same from the 753, didn't know what else was odd or different if I just decide to restore the 702 instead of the 753. Is one a more desirable tractor then the other? The only thing I have done on the 753 was get all the missing parts together and paint and redo the hood, so everything so far interchanges easily. Share this post Link to post Share on other sites
ACman 7,761 #2 Posted July 28, 2016 (edited) I'm no expert , but I think the main difference is the front axle with a tighter turning radius . Also our 753 has the dial adjust and the Quick hitch for implements . I'm sure someone else will fill in the blanks. Edited July 28, 2016 by ACman Share this post Link to post Share on other sites
prondzy 3,891 #3 Posted July 28, 2016 They are both common tractors, the only real visible differences, are the axle, the use of the steering drag link on the 702, and the brake pedal being a smaller flag on the 702 1 Share this post Link to post Share on other sites
T-Mo-(Moderator) 5,003 #4 Posted July 29, 2016 As mentioned, the axle on the 753 is different and improved over the 702. Share this post Link to post Share on other sites
Live4outdoors 151 #5 Posted July 30, 2016 I guess it's clear just stick to the 753...I hate to go backwards if the front axle is that much different Share this post Link to post Share on other sites
