seven
Wheelhorse 877
seven
Need to figure out why it isn't charging can someone point me in where to look first I cannot find a wiring diagram either
953 nut
Here you go.
gwest_ca
Here is the tractor operator manual and wiring
This manual has a section on the starter/generator
Garry
seven
OK thxs
seven
If I take off the  wire from the voltage regulator marked bat. And put a meter on it what voltage should I be getting off it I'm assuming about 13 ,or14 volts
cleat
I would leave it connected to the battery and check it.
Should ideally be between 14 and 15 volts to generate a good charge.
You may need to bring the engine RPM's up to get a good output.
Achto
Check out this site, explains starter gen and walks you through trouble shooting. www.simpletractors.com › Service › Electrical Systems .
  • Similar Content
    • Armin Buehlmann
      By Armin Buehlmann
      Hi,
      I read through a few related posts but my symptoms sound different.
      Have an '89-'90? Wheelhorse 520-H,  model 4120OE01.
      When I engage the PTO, the engine stalls. No fault indicators.
      However, everything else seems normal:
      - all lights work when pressing 'TEST'
      - when I engage the PTO without sitting on the seat, the engine also stalls, but the 'SEAT' light comes on. Normal.
      - when I try to start the engine with the PTO engaged, it won't start and 'PTO' lights up. Normal.
      - after disconnecting the load (2-stage snow blower belt in this case) from the PTO, I get the same problem, engine stalls immediately. PTO pulley turns along fine with the remaining motion.
      And I also need to mention: the first time it happened it was intermittent. The tractor and snowblower attachment were used over a month ago, without any problem.This time got above symptom upon startup. I didn't feel like shoveling so after revving the engine for a minute or two and a few 'encouraging' words, it worked.  I switched the PTO off and on several times afterwards with no problem (engine warm, obviously). Today, with the engine cold, the problem is back.
      I think there's enough reason to rule out the PTO- and seat- switches. But what else should I check?
      This is my first time writing in the forum and I hope I've given enough clues without boring you.
      Any hints and advice are appreciated.
      Armin
      PS any good tricks to counteract the belt tensioner on the 2-stage snow thrower (model 79361)? It is a bear to connect and disconnect.
    • indywheelhorsenut
      By indywheelhorsenut
      Started fine 2 weeks ago.  I left key in ignition and fear grandson may have turned it slightly to right a week ago.. not enough to engage starter but perhaps enough to drain battery.
      Went to start it yesterday and no charge at all.  Started charging it and battery began to take charge.  However starter turned over but didnt turn engine over.
      Question is do I just need more of a charge (more amps) or do I have another problem?
      Lol, have 5 inches of snow headed here starting tonight so I need to get ahead of this today.
    • firemanironman
      By firemanironman
      I picked up a wheel horse and I am having trouble finding the connection for this wire. I have no spark and  have searched for the placement of this wire within the distance of its length...any ideas?...can't seem to paste the picture....
    • MS GENERAL REPAIR
      By MS GENERAL REPAIR
      Part 1 of John Deere STX Lawn Tractor Repair Video Series.
      The Engine won't crank.
    • r1jakecfd
      By r1jakecfd
      Hi Guys,
      I know my voltage regulator is bad on my Onan P220 and was wondering if anyone has an opinion on a replacement, OEM or aftermarket?
      Also, I checked my stator leads for AC Voltage and got about 25 volts at 3600 rpm on each. Is this OK? I know it says in the 40’s.
      Thanks guys
